Re: AV10 walkin' cranks. Anyone else?
Jonathan Feldman /
> Moore Burns & Payne Crematorium Wrote:
> It smashes completely flat too. That would fix the .5- 3mm fluctuations.
> If the bearings are good fitting and the crank is floating, put a small
> spring washer between the bearing and crank. Collared around the shaft,
> touching only the inside ring of the bearing. That’ll take up the slack.
Wow that was an excellent write up. You are one of the few people on mopedarmy that give me hope for the future of mopeds. Lemme mentally process this and report back.
