Re: AV10 walkin' cranks. Anyone else?
Jonathan Feldman /
> JBOT Admin Wrote:
> Take it apart first and see for sure if it's bearing walk or crank walk.
> If it's bearing to case walk, its either poorly machines cases or your
> installation.
> If it's crank to bearing walk, it's probably the crank is just worn on
> the bearing placement spots, poor installation could cause this too.
> First find out what happened.
Banger reply as usual dawg.
You're definitely backing my poorly machined case hypothesis.
