had to make an intake... damn tomos plus damn square port. 5mm flat bar off fleabay and a NIBco elbow and here she is...
The puch side shooter sha intake works perfect on a tomos.
Is that electrical/plumber solder or silver solder? I don´t think tin solder can hold the vibrations and weight of a carb without cracking
harris staybrite 8 its mechanical properties r rediculous. 50 a pound
I'm tempted to make an adapter to put a Yamaha RX100 reed valve with its carb in a V1, I had a stick welder but I had not enough practice to make it decent. Don´t know if Silver Solder withstands the forces to support so much weight.
Silver solder done right would be plenty strong.
Good to know, might bring it a chance
