Re: Hobbit - can I squeeze 5more mph outta this thing?
derek from black pipes moped gang /
Nice!
Chris Carleton /
Lets take up a collection and get this guy a pipe!
Barry (Bob) Brown /
Got a pipe! Bought the Proma and wrapped it cause it made your ears bleed - a lot quieter now. Took off the baffle of the jammy and cut the tube and am going to spot weld it to the end of the Proma and pack it with some course stainless steel wool to try and see it I can quiet down some more. Any thoughts?
Brass wool doesn't rust . ;)
Emil Kniemel /
if you want a quiet pipe the proma is not it. MLM sidebleed is quiet and has good performance.
Barry (Bob) Brown /
tried to quite it down a bit but after tack welding the jammy baffle on and stuffing stainless steel wool in it, it was fairly unnoticeable so I took it off. But I finally got that 5mph out of it. I put in an 86 jet and it still 4 strokes a bit until its warmed up and takes a bit of road to get to 43, think it's tuning, air/fuel mix, timing/points gap?
