Re: El-cheapo Peugeot CDI vs. 5 coil
Daniel '' /
I am currently using the Ducati energia set up, but prior I was using a 5 coil. It works well, mount an external condenser and clean up the points. Its my go to on any other Peugeot I build. The only real benefit is the brighter lights from the cheapo, but you can get higher wattage coils and make the 5 coil have more output if you're electrically savvy.
