Jack Rutherford my comments are directed at the OP, not you. I used your posts to prove my point that adding only a pipe to a QT, will not provide decent HP.
You did a lot of extra work.
Too much work in my opinion.
> Bill Mazzacane Wrote:
> 18 degrees of BDT is the absolute minimum,
> but I wouldn't waste my time building or selling a
> tuned pipe unless the customer knew that changing BDT was essential to
> the performance of the engine.
> I don't know these companies, but if you (the OP) are under the opinion that you
> can bolt a pipe on to any stock cylinder and get decent HP, that isn't
> true.
> Bill M. (edited)
