Re: Jammer in tomos a35
It's possible that you have glazed the clutch pads, especially since you used the medium springs. I dont think your setup makes enough power to utilize the medium springs, and they slipped too much as a result and glazed over. I would take the clutch off and inspect it. If the pads are glazed, give em a light touch with some 220 grit sandpaper.
How much Atf are you using in the transmission?
