Re: Fuel injection
Douglas Binder /
Thomas, the reason I post the stuff I do is in case anyone wants to try it. The casting stuff is pretty straightforward but requires a lot of equipment. The EFI doesn't need too much except you need to come up with a trigger wheel. The issue is that there is a steep learning curve. You can buy some of the parts like the control board, etc, but then you need to get a throttle body somehow mated with your engine. I imagine that I will eventually cast the throttle body to reed housing adapter in aluminum but, for now, will use the 3D printed part. The throttle body that came with the kit has a built in intake air sensor, manifold pressure sensor, and throttle position sensor. Because there was no documentation, I only use the TPS and that was fun trying to figure out which wires to use. The thing is sealed up so I had to do some detective work. I have a lab grade power supply that I used to put 5 volts into the thing and watched the remaining wires while I moved the throttle.
I could go on but I should get back to work.
  Fuel injectionTopic by: Douglas Binder Douglas Binder 04/07/19 05:01PM
  Re: Fuel injectionRe: Douglas Binder Douglas Binder 04/07/19 05:03PM
  Re: Fuel injectionRe: Douglas Binder Douglas Binder 04/07/19 05:04PM
  Re: Fuel injectionRe: Douglas Binder Douglas Binder 04/07/19 05:06PM
  Re: Fuel injectionRe: Thomas TPRF Thomas TPRF 04/07/19 06:07PM
  Re: Fuel injectionRe: Mike Boyd Mike Boyd 04/07/19 06:41PM
  Re: Fuel injectionRe: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 04/07/19 09:25PM
  Re: Fuel injectionRe: Graham Motzing Graham Motzing 04/08/19 09:36AM
  Re: Fuel injectionRe: Douglas Binder Douglas Binder 04/08/19 09:49AM
  Re: Fuel injectionRe: Graham Motzing Graham Motzing 04/08/19 11:20AM
  Re: Fuel injectionRe: Totally normal JBOT Totally normal JBOT 04/08/19 11:40AM
  Re: Fuel injectionRe: Alex hernandez Alex hernandez 04/08/19 05:39PM
  Re: Fuel injectionRe: Josiah Radebaugh Josiah Radebaugh 04/08/19 07:42PM
  Re: Fuel injectionRe: Derek Stahl Derek Stahl 04/09/19 11:09AM
  Re: Fuel injectionRe: Thomas TPRF Thomas TPRF 04/09/19 11:40AM
  Re: Fuel injectionRe: Douglas Binder Douglas Binder 04/09/19 01:12PM
  Re: Fuel injectionRe: Thomas TPRF Thomas TPRF 04/10/19 10:09AM
  Re: Fuel injectionRe: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 04/09/19 07:18PM
  Re: Fuel injectionRe: Douglas Binder Douglas Binder 04/09/19 08:32PM
  Re: Fuel injectionRe: Douglas Binder Douglas Binder 04/10/19 10:40AM
  Re: Fuel injectionRe: * * * * 04/10/19 10:59PM
  Re: Fuel injectionRe: Douglas Binder Douglas Binder 04/11/19 09:50AM
  Re: Fuel injectionRe: * * * * 04/11/19 10:12PM
