Av10 rotary valve
Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F /
Right now I’m in early experimentation, but have the correct measurements and am building it to just see if I can. I plan to use the Tormach at my local makerworks to mill this whenever I have the time but currently I am 3D printing a model.
Re: Av10 rotary valve
Also if any of you are skilled in writing G code if you could look over my operation. I’ve run simple parts but none really this complex
This is a (rotary valve) motor
Yes, where there’s a disc controlling the timing. Im trying to base it off of Alex degnes design
There isnt that much of a benefit rotary vs reed valve. So much engineering and planning. I would just make your cases take dirtbike reeds, kx80 or similar, use a scooter crank and have a minarelli horizontal stud pattern. Basically like the mykitech cases.
cool!
i've been using 3d printing a ton at work lately to double check before getting something machined. it sounds stupid, you'd think after months of figuring and working on shit in cad you could get it right, but having that 3d printed mock up is so huge from a confidence perspective
you can also fixture it in the CNC machine before you run it and have the CNC 'trace' the 3d printed part just to 2x check the code, if it crashes its just plastic and it wil give.
