What is this middle intake port on a DOS av10 70cc kit
Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F /
It looks as it doesn’t connect to the actual intake in the case like the other 2 and I’m just wondering what the purpose of it is
Re: What is this middle intake port on a DOS av10 70cc kit
Totally normal JBOT /
Those are all boost ports.
If they're not connected to the main boost tunnel coming out of the cases then you should connect them. I drill them to meet up then dremel to make it flowy.
You'll make more power
its there to give the other two company.
