Performance Vespa grande?
Alexandro Ramirez-Nagy /
I've got a vespa grande that I've been planning to do some performance to for a while. The second owner "de-restricted the pipe" which is true because the pipe has been cut and re-welded and it seems to be de-restricted. Where should I start? I've already got a 13.13 and hi-flow air filter by mallossi. Do I need to do anything to the clutch bell before anything else or am I good to go? I wanna know where to start.
Re: Performance Vespa grande?
Josiah Radebaugh /
I figure since the goal is 40-45... Clutch bell maybe... Anyway. Porting, might consider a 14.12. And some variation mods
Dirty30 Dillon /
1) Modifying the clutch bell will not increase any performance.
2) Porting the intake patch and cutting the crank for increased duration helps a lot, but the stock US Vespa cylinders are pretty sad and erratically timed/ported. Most fail to open the ports at BDC or have a giant squish... or both.
3) The 14.12 will not fit and is actually a smaller ID carb. The 13.13 is also useless unless you have opened the intake spigot to match.
If you want 40-45, I think the simplest way is going to be a nice circuit pipe, a 43mm kit and some basic intake patch and inlet porting work.
There is SO much vespa info in the wiki. Read it thoroughly because Vespa's are unique in a lot of ways from most other motors on mopeds.
+1 for slap on a malossi kit and lie that you go 45
1935 OP
This may be a dumb question, but how difficult would it be to put a Vespa grande engine on a ciao?
The engine is the same in both bikes.
the cylinder head is different, bravo/grande cylinder head don't fit in a ciao frame
> a ciao frame
Oops, forgot about that part.
1935 OP
thanks
