Re: Puch maxi carb problems
Graham Motzing /
you will need to increase your main jet size, not sure where you will be with the 28 mm stock style pipe but my guess is high 70's
also the bushing crank will not last long turning high rpm from the 14x45 gearing. when it starts making rattley sounds stop before you blow it up and replace the crank.
