Ok here is the skinny on the Tomos clutches. Use vibraam rubber for pads. If possible slot an a35's clutch hubs to use a3 shoes.
Replace with pivot pin in back so it opens toward rotation instead of away...swap out your tranny fluid with marvel mystery oil and c astrol atf at 4/1. The downshift is. Controlled by the internal countershaft Kickstarter cage and associated question mark spring.
