Tomos Streetmate Exhaust
Everett Goen /
I've recently purchased my first moped, a 2008 Tomos Streetmate. I'm looking to squeeze some more power out of it though, as it barely does 30 mph right now. I'm probably going to buy the Techno Bullet for the A55, but I want to know how the jetting works and what jets I need to buy with my exhaust upgrade. Also, I have the stock 31 tooth sprocket on the rear, and if anyone could help me locate a smaller sprocket that would fit my ped that would be great. Thanks
Re: Tomos Streetmate Exhaust
treatland.tv
62-64 jet, high flow metal mesh filter, 26x26 gearing, bullet pipe=happy times. Also blue spring on first gear, yellow on second is a decent clutch upgrade if your pads are still good.
Leave your clutches alone, get cheap techno or BiTurbo, 27t front 22t rear sprocket, upjet at least to a 58-66 6mm dellorto PHVA main jet, 42 or 45 idle jet and get an ngk bh8es spark plugs and you're looking at a steady 42mph up to 48 ish.
what conan said keep it simple
