Re: Deristricting Vespa variator....
Ike Pipe /
I use a drill press for mine, but you could use a drill. I also use vice grips. As far as marring them, remember you have plastic caps to go over them, so it shouldn't be a big deal. Alternatively, I use a bit of old tire tube to wrap around the weight and then clamp with vise grips.
I've ground the collars on several bikes and I don't notice a very large change. Lightening the weights helps a lot with acceleration, however.
I tell you what though, nothing beats a Polini. I'd get that before a kit any day. It just changes your whole world.
Malossi is good, but Polini is better.
  Deristricting Vespa variatorTopic by: Les B. Les B. 03/16/19 11:07AM
  Re: Deristricting Vespa variatorRe: Totally normal JBOT Totally normal JBOT 03/16/19 12:36PM
  Re: Deristricting Vespa variatorRe: alex . alex . 03/16/19 05:00PM
  Re: Deristricting Vespa variatorRe: Les B. Les B. 03/17/19 12:11PM
  Re: Deristricting Vespa variatorRe: Les B. Les B. 03/17/19 01:13PM
  Re: Deristricting Vespa variatorRe: alex . alex . 03/18/19 11:48AM
  Re: Deristricting Vespa variatorRe: Dirty30 Dillon Dirty30 Dillon 03/18/19 11:57AM
  Re: Deristricting Vespa variatorRe: Les B. Les B. 03/18/19 04:02PM
  Re: Deristricting Vespa variatorRe: Seth B Seth B 03/18/19 04:06PM
  Re: Deristricting Vespa variatorRe: Dirty30 Dillon Dirty30 Dillon 03/18/19 04:07PM
  Re: Deristricting Vespa variatorRe: Seth B Seth B 03/18/19 05:44PM
  Re: Deristricting Vespa variatorRe: alex . alex . 03/19/19 11:54PM
  Re: Deristricting Vespa variatorRe: kevin Smellaflange kevin Smellaflange 03/17/19 01:21PM
  Re: Deristricting Vespa variator....Re: Les B. Les B. 03/17/19 04:55PM
  Re: Deristricting Vespa variator....Re: Ike Pipe Ike Pipe 03/17/19 07:58PM
  Re: Deristricting Vespa variator....Re: Les B. Les B. 03/18/19 06:57AM
  Re: Deristricting Vespa variator....Re: Ike Pipe Ike Pipe 03/18/19 08:45PM
  Re: Deristricting Vespa variatorRe: Les B. Les B. 03/18/19 04:32PM
  Re: Deristricting Vespa variatorRe: Les B. Les B. 03/20/19 11:24AM
  Re: Deristricting Vespa variatorRe: Seth B Seth B 03/20/19 12:08PM
  Re: Deristricting Vespa variatorRe: - Joe - - Joe - 03/20/19 01:16PM
  Re: Deristricting Vespa variatorRe: Seth B Seth B 03/20/19 01:38PM
  Re: Deristricting Vespa variatorRe: Ike Pipe Ike Pipe 03/21/19 01:43AM
  Re: Deristricting Vespa variatorRe: Graham Motzing Graham Motzing 03/20/19 01:40PM
  Re: Deristricting Vespa variatorRe: Les B. Les B. 03/20/19 02:42PM
  Re: Deristricting Vespa variatorRe: Seth B Seth B 03/20/19 03:07PM
  Re: Deristricting Vespa variatorRe: Graham Motzing Graham Motzing 03/20/19 03:11PM
  Re: Deristricting Vespa variatorRe: Seth B Seth B 03/20/19 04:50PM
  Re: Deristricting Vespa variatorRe: Les B. Les B. 03/20/19 05:37PM
  Re: Deristricting Vespa variatorRe: Seth B Seth B 03/20/19 06:51PM
  Re: Deristricting Vespa variatorRe: Graham Motzing Graham Motzing 03/21/19 01:38PM
  Re: Deristricting Vespa variatorRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 03/24/19 03:18PM
  Re: Deristricting Vespa variatorRe: Les B. Les B. 03/21/19 06:21PM
  Re: Deristricting Vespa variatorRe: Seth B Seth B 03/21/19 10:09PM
  Re: Deristricting Vespa variatorRe: Paris M Paris M 03/22/19 04:26AM
  Re: Deristricting Vespa variatorRe: Graham Motzing Graham Motzing 03/22/19 10:56AM
  Re: Deristricting Vespa variatorRe: Seth B Seth B 03/22/19 02:57PM
  Re: Deristricting Vespa variatorRe: cheetahchrome . cheetahchrome . 03/23/19 10:27AM
  Re: Deristricting Vespa variatorRe: Les B. Les B. 03/23/19 12:33PM
  Re: Deristricting Vespa variatorRe: alex . alex . 03/24/19 01:00AM
  Re: Deristricting Vespa variatorRe: Les B. Les B. 03/24/19 03:08PM
  Re: Deristricting Vespa variatorRe: Brit Wilkens Brit Wilkens 03/28/19 12:20AM
  Re: Deristricting Vespa variatorRe: alex . alex . 04/02/19 01:14AM
  Re: Deristricting Vespa variatorRe: Graham Motzing Graham Motzing 04/02/19 11:07AM
  Re: Deristricting Vespa variatorRe: Seth B Seth B 04/02/19 07:13PM
  Re: Deristricting Vespa variatorRe: Graham Motzing Graham Motzing 03/28/19 12:29PM
