Re: first bike
Overpriced Parts /
> Graham Motzing Wrote:
> i'd order a clutch cover gasket, pop the cover, hose it out in there
> with a can of brake cleaner, check the clutches, pop a new gasket in
> there, put the cover back on and fill with the proper amount of ATF.
> tomos transmissions for some reason tend to be full of nasty and it will
> kill bearings and gears. If you ride them regular like, and change the
> fluid, they stay pretty clean but whenever i buy one that has sat you
> find a lot of sludge [cork] in the transmission.
