Re: first bike
Graham Motzing /
i'd order a clutch cover gasket, pop the cover, hose it out in there with a can of brake cleaner, check the clutches, pop a new gasket in there, put the cover back on and fill with the proper amount of ATF.
tomos transmissions for some reason tend to be full of nasty and it will kill bearings and gears. If you ride them regular like, and change the fluid, they stay pretty clean but whenever i buy one that has sat you find a lot of sludge in the transmission.
