Re: Le Moped Resurrection
Garelli Master✨ /
> > > > Head bushings installed.
> > > Awesome build. Love it.
> > > Where did you get the head bushings? Can't find any. I been
> searching
> > > and searching for one of them on my head, and then I saw a picture I
> > > took while tearing the moped down, it never had one!
> > > Everywhere I look, sold out.
> > > Thanks
> > How many of the bushings do you need?
> I would need 1 bushing total. Somehow there was only one on there when I
> took apart the motor. Actually, I can't put this back together unless I
> get one I guess.
> I thought they were both the same size but I see there is a longer one?
> Thanks
The stock ones were the same size. Someone made others different thickness I guess to really dial in the belt alignment?
  Le Moped ResurrectionTopic by: Garelli Master✨ Garelli Master✨ 02/19/19 03:13PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/19/19 03:18PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/19/19 03:21PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/19/19 03:27PM
  Re: Le Moped ResurrectionRe: Graham Motzing Graham Motzing 02/19/19 03:48PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/19/19 03:58PM
  Re: Le Moped ResurrectionRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/19/19 04:35PM
  Re: Le Moped ResurrectionRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 02/19/19 06:12PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/19/19 06:52PM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 02/20/19 02:23PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/20/19 02:24PM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 02/20/19 04:19PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/20/19 04:57PM
  Re: Le Moped ResurrectionRe: Stephen Keller Stephen Keller 02/23/19 04:18PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 04:22PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 05:20PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 05:21PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 05:24PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 05:25PM
  Re: Le Moped ResurrectionRe: French Moby French Moby 05/07/19 11:12PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/08/19 03:28AM
  Re: Le Moped ResurrectionRe: French Moby French Moby 05/08/19 06:02PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/08/19 06:08PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 07:29PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 07:33PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 08:44PM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 02/24/19 06:58PM
  Re: Le Moped ResurrectionRe: Daniel '' Daniel '' 02/25/19 11:51AM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/25/19 05:31PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/26/19 10:03AM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/25/19 05:35PM
  Re: Le Moped ResurrectionRe: Peter Turenne Peter Turenne 02/28/19 07:25PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/01/19 12:51AM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/01/19 12:18PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/15/19 04:25PM
  Re: Le Moped ResurrectionRe: Stephen Keller Stephen Keller 03/16/19 09:12PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/15/19 04:28PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/15/19 08:59PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/15/19 09:01PM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 03/16/19 09:54AM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/16/19 10:33AM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 03/17/19 01:14PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/17/19 04:55PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/25/19 11:12PM
  Re: Le Moped ResurrectionRe: Stephen Keller Stephen Keller 03/26/19 01:09AM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/26/19 05:18PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/26/19 05:19PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/26/19 05:20PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/27/19 08:03PM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 03/31/19 12:04PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/31/19 02:39PM
  Re: Le Moped ResurrectionRe: Daniel '' Daniel '' 03/31/19 04:03PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/31/19 06:21PM
  Re: Le Moped ResurrectionRe: Marc Andre de Seve Marc Andre de Seve 04/28/19 07:29PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 04/28/19 08:45PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/03/19 01:31PM
  Re: Le Moped ResurrectionRe: Graham Motzing Graham Motzing 05/03/19 02:42PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/03/19 01:51PM
  Re: Le Moped ResurrectionRe: Daniel '' Daniel '' 05/03/19 01:52PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/03/19 02:38PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/07/19 03:18PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/21/19 02:37PM
