Re: Le Moped Resurrection
Graham Motzing /
yeah the 47 mm mbk heads tat i make for dos cycles, i find that about 2/10 cores are rejects because of how sloppy they machine that hole. I guess we had one from the last batch looked like it was good but ended up blowing out anyhow... probably not going to make them any more just for that reason.
i'm not sure if some of the higher end (doppler, etc) heads have the decomp machined farther out but there is only so far you can go for backwards compatability.
  Le Moped ResurrectionTopic by: Garelli Master✨ Garelli Master✨ 02/19/19 03:13PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/19/19 03:18PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/19/19 03:21PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/19/19 03:27PM
  Re: Le Moped ResurrectionRe: Graham Motzing Graham Motzing 02/19/19 03:48PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/19/19 03:58PM
  Re: Le Moped ResurrectionRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/19/19 04:35PM
  Re: Le Moped ResurrectionRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 02/19/19 06:12PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/19/19 06:52PM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 02/20/19 02:23PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/20/19 02:24PM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 02/20/19 04:19PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/20/19 04:57PM
  Re: Le Moped ResurrectionRe: Stephen Keller Stephen Keller 02/23/19 04:18PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 04:22PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 05:20PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 05:21PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 05:24PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 05:25PM
  Re: Le Moped ResurrectionRe: French Moby French Moby 05/07/19 11:12PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/08/19 03:28AM
  Re: Le Moped ResurrectionRe: French Moby French Moby 05/08/19 06:02PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/08/19 06:08PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 07:29PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 07:33PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 08:44PM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 02/24/19 06:58PM
  Re: Le Moped ResurrectionRe: Daniel '' Daniel '' 02/25/19 11:51AM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/25/19 05:31PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/26/19 10:03AM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/25/19 05:35PM
  Re: Le Moped ResurrectionRe: Peter Turenne Peter Turenne 02/28/19 07:25PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/01/19 12:51AM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/01/19 12:18PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/15/19 04:25PM
  Re: Le Moped ResurrectionRe: Stephen Keller Stephen Keller 03/16/19 09:12PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/15/19 04:28PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/15/19 08:59PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/15/19 09:01PM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 03/16/19 09:54AM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/16/19 10:33AM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 03/17/19 01:14PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/17/19 04:55PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/25/19 11:12PM
  Re: Le Moped ResurrectionRe: Stephen Keller Stephen Keller 03/26/19 01:09AM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/26/19 05:18PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/26/19 05:19PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/26/19 05:20PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/27/19 08:03PM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 03/31/19 12:04PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/31/19 02:39PM
  Re: Le Moped ResurrectionRe: Daniel '' Daniel '' 03/31/19 04:03PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/31/19 06:21PM
  Re: Le Moped ResurrectionRe: Marc Andre de Seve Marc Andre de Seve 04/28/19 07:29PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 04/28/19 08:45PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/03/19 01:31PM
  Re: Le Moped ResurrectionRe: Graham Motzing Graham Motzing 05/03/19 02:42PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/03/19 01:51PM
  Re: Le Moped ResurrectionRe: Daniel '' Daniel '' 05/03/19 01:52PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/03/19 02:38PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/07/19 03:18PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/21/19 02:37PM
