Re: Le Moped Resurrection
Garelli Master✨ /
> Daniel '' Wrote:
> What # gas strut are you using? 50# is perfect for the stock 3 ball,
> mild kit, stock pipe. I havent ever used the ceramic balls, if I have a
> 4 ball var I usually just use two steel balls.
Yes 50lb strut with 4 ceramic balls. I'm going to change them out for 2 stock balls and I also have a 30 and 40lb strut so I'll get it dialed in shortly.
  Le Moped ResurrectionTopic by: Garelli Master✨ Garelli Master✨ 02/19/19 03:13PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/19/19 03:18PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/19/19 03:21PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/19/19 03:27PM
  Re: Le Moped ResurrectionRe: Graham Motzing Graham Motzing 02/19/19 03:48PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/19/19 03:58PM
  Re: Le Moped ResurrectionRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/19/19 04:35PM
  Re: Le Moped ResurrectionRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 02/19/19 06:12PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/19/19 06:52PM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 02/20/19 02:23PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/20/19 02:24PM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 02/20/19 04:19PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/20/19 04:57PM
  Re: Le Moped ResurrectionRe: Stephen Keller Stephen Keller 02/23/19 04:18PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 04:22PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 05:20PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 05:21PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 05:24PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 05:25PM
  Re: Le Moped ResurrectionRe: French Moby French Moby 05/07/19 11:12PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/08/19 03:28AM
  Re: Le Moped ResurrectionRe: French Moby French Moby 05/08/19 06:02PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/08/19 06:08PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 07:29PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 07:33PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/23/19 08:44PM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 02/24/19 06:58PM
  Re: Le Moped ResurrectionRe: Daniel '' Daniel '' 02/25/19 11:51AM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/25/19 05:31PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/26/19 10:03AM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 02/25/19 05:35PM
  Re: Le Moped ResurrectionRe: Peter Turenne Peter Turenne 02/28/19 07:25PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/01/19 12:51AM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/01/19 12:18PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/15/19 04:25PM
  Re: Le Moped ResurrectionRe: Stephen Keller Stephen Keller 03/16/19 09:12PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/15/19 04:28PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/15/19 08:59PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/15/19 09:01PM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 03/16/19 09:54AM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/16/19 10:33AM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 03/17/19 01:14PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/17/19 04:55PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/25/19 11:12PM
  Re: Le Moped ResurrectionRe: Stephen Keller Stephen Keller 03/26/19 01:09AM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/26/19 05:18PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/26/19 05:19PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/26/19 05:20PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/27/19 08:03PM
  Re: Le Moped ResurrectionRe: kevin Smellaflange kevin Smellaflange 03/31/19 12:04PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/31/19 02:39PM
  Re: Le Moped ResurrectionRe: Daniel '' Daniel '' 03/31/19 04:03PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 03/31/19 06:21PM
  Re: Le Moped ResurrectionRe: Marc Andre de Seve Marc Andre de Seve 04/28/19 07:29PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 04/28/19 08:45PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/03/19 01:31PM
  Re: Le Moped ResurrectionRe: Graham Motzing Graham Motzing 05/03/19 02:42PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/03/19 01:51PM
  Re: Le Moped ResurrectionRe: Daniel '' Daniel '' 05/03/19 01:52PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/03/19 02:38PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/07/19 03:18PM
  Re: Le Moped ResurrectionRe: Garelli Master✨ Garelli Master✨ 05/21/19 02:37PM
