Le Moped Resurrection
So I was given this in rough shape but the more I look at it it's not really that rough. So I been thinking a plan for it for a while now.
Re: Le Moped Resurrection
Garelli Master✨ /
I decided to go with the 50mm 82ish cc Parmakit build. I'm hoping for a daily lower reving torque monster so I'm going to be running a circuit pipe on this one.
Garelli Master✨ /
This thing is REALLY huge.....
Garelli Master✨ /
I'm getting copper base gaskets made at 2mm thickness to get port timing right. I'm also getting copper head gaskets made without decompression hole because the decompression hole is soooo close to the bore I'm not sure how to plug it without possibly upsetting the bore.
thats rad!
hope you keep the seat
cruiser-style le moped is the last bike on my bucket list to own.
Garelli Master✨ /
> Graham Motzing Wrote:
> thats rad!
Yes sir the seat is definitely staying! If I can't find the OG seat cover it's going to a upholstery shop to get covered. The foam is still damn near perfect.
WOOF
Downhill Harvey (OFMC) /
Someone switched out the mags, for spokes. Every LeMoped I've seen had gold mags :(
Garelli Master✨ /
> gold mags :(
True. I have a set of mags but not like the ones that came on it.
kevin Smellaflange /
are u using carbon fiber reeds?
how much did that set up cost?
are u using an AMALor DELORTTO?
24mm?
Garelli Master✨ /
> 24mm?
Fiber reeds. $60. 17-19mm phbg
are u putting a brass sleeve in the head motor mount
area?
keep the pics coming, this is sweet
Garelli Master✨ /
> area?
I'm definitely going to have to shim it to line the belt up.
Bump for awesomeness!
Garelli Master✨ /
I'm actually working on this as I'm typing. I'm kinda really excited about this!
Garelli Master✨ /
Well these were toast as usual
Garelli Master✨ /
New ones installed
Garelli Master✨ /
I've had this tool for a few years and it's still going strong! If you don't have one and work on Moby's as much as I do get you one. Well worth the $50 imo.
Garelli Master✨ /
Head bushings installed.
Garelli Master✨ /
So the angle of the carb on Sha polini intake REALLY sucks! So that'll be changed.
Garelli Master✨ /
Meanwhile I'm tweaking the shock variator with new starter shoes, 4 ball guide and ceramic balls. I'm also going gas strut on this one also because I don't feel like fighting the stock spring to line up with the mounting bracket.
Garelli Master✨ /
So this is how far I got. A couple of bolts rung off so I have to order two pins and 4 bolts. I would get a new variator but haven't read anything really good about them so I'm going to rebuild this one.
where did you get your ceramic variator balls?
how much $$$?
how many grams are they?
i know stock are around 10 grams or so.
Same place he got the gas shock. Mcmastercarr
Garelli Master✨ /
This
Garelli Master✨ /
So I had a 2.75 - 17 laying around and thought I'd try it out on the back and it fits! Got about 1/4" on both sides.
Garelli Master✨ /
> how much $$$?
https://www.mcmaster.com/ceramic-balls
It's the 1/2" balls
Peter Turenne /
Now this is a sick build! Makes me want to get back in the garage and get this TSM finished!
Garelli Master✨ /
Getter done!
Garelli Master✨ /
So I did this this morning. I got the pins from treatland and they are a little bigger like the comments said. I was able to take a 5/16 drill bit and redrill the he holes and the pins press in nice and tight! Then I flipped it over and brad the back with a hammer. Now to clean her up and assemble.
