Re: Bore stroke porting and displacement
Chöschi21 C.K. /
> Brad William Wrote:
> Most interested in better overall steady
> torque curve 0 - 35 mph. While im here asking.... Carb recommenations?
> Vm18? 15mm bing? The bing appeals for simplicity sake. But i do have
> bad memories of wishing i had more than just a needle setting when
> tuning the 12mm bings that came oem on my two puchs.
12mm Bing is fine, 14 if you have it, you can tune with changing the Needle and Needle Holder, if you don't change them around you can't use an Airfilter that flows more than Stock.
