Re: Bore stroke porting and displacement
Probably Fred /
> Brad William Wrote:
> How can the bings still be used with kits and aftermarket pipes? The
> only adjustments to such a wide range of demands imposed, beyond the
> very specific ones the oem bings were designed for, are needle slots
> and intake restrictors. Isnt any attempt to match them with different
> cylinders and pipes just badly limited from the start?
I get 56-57 mph with 64cc polini reed kit, on a e50, horrible case match, 15mm bing, 90 jet, 217 atomizer, one clip heavy on needle, 14.5° BTDC timing and cheep estroil pipe
I’ve hit 62 mph with better mlm pipe
Bings rule but-so does mikuni, dellorto and other carbs once tuned !
Be off a fraction in jetting and your bike will be a dog but be tuned perfect and you got a small motorcycle
