Re: Bore stroke porting and displacement
Probably Fred /
> Graham Motzing Wrote:
> in a nutshell raising the port raises the power band, stock puch
> cylinder powerband is from like 2000-4000 rpm, that kit is probably
> ported out of the box to 6000-8000 rpm
> i'd suggest reading Jennings '2 stroke tuning' as a primer into the
> world of tuning two strokes. Bell is also a good read and more current,
> its higher level stuff in some instances but a novice can still follow
> it pretty well.
> If you're going to buy one, I prefer the Bell book.
Stock puch powerband with stock pipe goes to 6,500 +rpm, With aftermarket pipe could go way higher like 9-10,000 rpm
Unported cylinder with stock exhaust with one extra hole in it . Oh yeah junk airbox and snorkel thrown away as usual and mesh filter used, that’s what stops a puch from reving,
Sounds like a lot more then 4,000 rpm to me:
