Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.
Ryan . /
> Dirty30 Dillon Wrote:
> Of course it will have no problem, because it is super short gearing.
> The problem is not pulling tall gearing, it's about being stuck in
> over-rev at 43.4 mph
Right, the bike will be wheezing at 2/3 of it's potential top speed and causing a lot of heat buildup and wear with the potential failures far more likely. And for what, to cruise at 32 mph with a top speed just over 40?
This is exactly the reason I literally put my NC50 to the curb after tons of tinkering with exhaust work, porting, intake and carb etc. I got it to do 43mph on the stock cylinder but it was howling to even go 35 and the heat buildup had me shutting it down after a couple of miles just cruising. I am not trying to specifically compare the two instances because the cooling ability of the two engines will be significantly different but it was the realization that I was stuck with a fixed ratio that I would never be able to see the potential of the build. Even trying to casually ride the bike in the way I wanted (cruising 40-45) was going to result in a lot of heartache when it turned out to be a grenade every time.
  tomos Arrow/E50 build. Gearing is weird. Need suggestions.Topic by: Jaxx Parrow Jaxx Parrow 02/18/19 03:17PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/18/19 03:54PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Jaxx Parrow Jaxx Parrow 02/19/19 02:19AM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Chöschi21 C.K. Chöschi21 C.K. 02/18/19 03:55PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Jaxx Parrow Jaxx Parrow 02/19/19 02:26AM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Ben Whittle Ben Whittle 02/18/19 06:48PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/18/19 09:59PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Saabsonettguy . Saabsonettguy . 02/19/19 10:03AM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: P D P D 02/19/19 10:07AM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Overpriced Parts Overpriced Parts 02/19/19 11:34AM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Ryan . Ryan . 02/19/19 03:47PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Overpriced Parts Overpriced Parts 02/19/19 05:41PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Ryan . Ryan . 02/19/19 07:22PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Jaxx Parrow Jaxx Parrow 02/19/19 08:33PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Ryan . Ryan . 02/19/19 09:06PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: P D P D 02/20/19 11:05AM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Daniel '' Daniel '' 02/20/19 05:20PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Overpriced Parts Overpriced Parts 02/20/19 05:44PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Overpriced Parts Overpriced Parts 02/20/19 03:38PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: mit mortso mit mortso 02/20/19 07:41PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Rocco Taco Rocco Taco 02/20/19 10:45PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Rocco Taco Rocco Taco 02/21/19 12:03AM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Overpriced Parts Overpriced Parts 02/21/19 02:57AM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Rocco Taco Rocco Taco 02/21/19 02:23PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Ryan . Ryan . 02/21/19 06:02PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Overpriced Parts Overpriced Parts 02/21/19 06:10PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Rocco Taco Rocco Taco 02/21/19 09:43PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Dirty30 Dillon Dirty30 Dillon 02/22/19 09:06AM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Ryan . Ryan . 02/22/19 11:25AM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Daniel '' Daniel '' 02/22/19 11:52AM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Rocco Taco Rocco Taco 02/22/19 03:07PM
  Re: tomos Arrow/E50 build. Gearing is weird. Need suggestions.Re: Chöschi21 C.K. Chöschi21 C.K. 02/22/19 12:37PM
