Re: 70cc kit increase
Chöschi21 C.K. /
The Piston Pin, there were Tomos Crankshafts that accept 10mm Pins and 12mm Pins, need to wach out for that, a Crank made for a 10mm Pin won't accept a 12mm Pin, and a Crank made for a 12mm Pin will accept a 10mm Pin but won't run because it will have faaaaaaar to much Play in it, so for an Engine that has the 10mm Pin you need a kit with a 10mm Pin and for an Engine wit a 12mm Pin you will need a Kit with a 12mm Pin, otherwise it won't work.
