Re: 70cc kit increase
Chöschi21 C.K. /
> Bob Selby Wrote:
> No MPH increase unless you change the gear ratio... You must up-jet with
> better air filter...And Trail-tech temp gauge for insurance...
Dunno what drugs you are on to not get a Speed difference without Gearing.
I built a bike for a Guy, was a 30kmh(18.whatever MPH) model:
https://www.treatland.tv/tomos-A35-airsal-kit-p/tomos-a35-airsal-kit-02210244.htm
https://www.treatland.tv/tomos-A35-biturbo-pipe-p/biturbo-tomos-a35.htm
https://www.treatland.tv/dellorto-SHA-14-14-carburetor-p/dellorto-sha-14.14-lever-01682.htm
Also drilled out the Intake to 14mm and got an easy 37mph out of it, with the stock Gearing, don't know what it was, but i just slapped on the Parts and tuned the Carb and ran it, was the first and only one i modified. But WARNING!!!! The stock Tomos Frames are made like crap, seen a lot of them Crack and even break at minor crashes, seems like they are made out of Styrofoam
To answer your actual Questions, you need:
-the Kit
-a 14-16mm Carb
-an intake that fits it, never use an Intake that has a smaller inner diameter than the Carb
-an Exhaust with a bigger Diameter, Tecno Boss and Biturbo for instance are okay for a normal bike build.
-Carb Jets
-A cylinder head that fits the Kit
also you will have to modify the Air Filter to take more Air, the one on the Bike i built had a flow restrictor.
If you like how the Bike runs and you got everything dialed in you can mess around with the Gearing if you like.(edited)
