Re: Garelli crazy high idle on stand. On the ground idles great
Luke Whinham /
> pat splat Wrote:
> look to see that your throttle slide closes all the way, should be
> closed all the way and not hung up. if its closed and still idling high
> then u got an air leak, youll seize when its running and too lean on
> top.
Cool I will check this afternoon and again for air leaks. Thanks
  Garelli crazy high idle on stand. On the ground idles greatTopic by: Luke Whinham Luke Whinham 02/11/19 02:00PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: JBOT Admin JBOT Admin 02/11/19 02:49PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Luke Whinham Luke Whinham 02/11/19 03:06PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: JBOT Admin JBOT Admin 02/11/19 10:21PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: alex . alex . 02/11/19 03:18PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Luke Whinham Luke Whinham 02/11/19 03:24PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: alex . alex . 02/11/19 04:29PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: pat splat pat splat 02/11/19 05:07PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Luke Whinham Luke Whinham 02/12/19 07:49AM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Dirty Mike Dirty Mike 02/12/19 08:34AM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Luke Whinham Luke Whinham 02/12/19 12:11PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Stephen Simmons Stephen Simmons 02/12/19 12:22PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: todd amundson todd amundson 02/11/19 09:03PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Luke Whinham Luke Whinham 02/12/19 07:48AM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Born to be WillD Born to be WillD 02/12/19 02:27PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: todd amundson todd amundson 02/13/19 10:38AM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Dirty Mike Dirty Mike 02/13/19 05:14PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Kevin Bishop Kevin Bishop 02/15/19 06:50PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Tyler Hautau Tyler Hautau 02/20/19 09:03PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Mike Boyd Mike Boyd 02/22/19 09:25PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Sean Colvin Sean Colvin 01/14/20 01:20PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Born to be WillD Born to be WillD 01/14/20 02:12PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Anonymous User Anonymous User 01/15/20 07:17AM
