Re: Garelli crazy high idle on stand. On the ground idles great
todd amundson /
Dude this is a Garelli NOI. As soon as you bring its ass end up the rubber clutch takes the rear wheel for a ride. The faster the wheel spins the higher engine rpm goes. And in no way can you bring down idle speed via the screw to control this problem/ because then you let the wheel down and the engine dies because you can't get the stupid rubber clutch to disengage. In L.A. we now run urethane.
  Garelli crazy high idle on stand. On the ground idles greatTopic by: Luke Whinham Luke Whinham 02/11/19 02:00PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: JBOT Admin JBOT Admin 02/11/19 02:49PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Luke Whinham Luke Whinham 02/11/19 03:06PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: JBOT Admin JBOT Admin 02/11/19 10:21PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: alex . alex . 02/11/19 03:18PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Luke Whinham Luke Whinham 02/11/19 03:24PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: alex . alex . 02/11/19 04:29PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: pat splat pat splat 02/11/19 05:07PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Luke Whinham Luke Whinham 02/12/19 07:49AM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Dirty Mike Dirty Mike 02/12/19 08:34AM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Luke Whinham Luke Whinham 02/12/19 12:11PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Stephen Simmons Stephen Simmons 02/12/19 12:22PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: todd amundson todd amundson 02/11/19 09:03PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Luke Whinham Luke Whinham 02/12/19 07:48AM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Born to be WillD Born to be WillD 02/12/19 02:27PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: todd amundson todd amundson 02/13/19 10:38AM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Dirty Mike Dirty Mike 02/13/19 05:14PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Kevin Bishop Kevin Bishop 02/15/19 06:50PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Tyler Hautau Tyler Hautau 02/20/19 09:03PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Mike Boyd Mike Boyd 02/22/19 09:25PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Sean Colvin Sean Colvin 01/14/20 01:20PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Born to be WillD Born to be WillD 01/14/20 02:12PM
  Re: Garelli crazy high idle on stand. On the ground idles greatRe: Anonymous User Anonymous User 01/15/20 07:17AM
