Re: Playing with puch
Totally normal JBOT /
> Thomas TPRF Wrote:
> > JBOT Admin Wrote:
> > Pics of the carnage?
> It was my attempt to run an Airsal piston in a Polini cylinder since I
> I couldn't find a Polini piston in a large enough oversize to account
> for how much the cylinder had to be over overbored after the last
> failure.
> The skirt used to have a window in it rather than a slot. I'm thinking
> maybe I should have cut that into a slot? Probably didn't chamfer things
> enough either.
> Worst part is it stopped hard with a chunk of metal in a port so I'm
> worried that the crank may be tweaked.
the base of the boost in the cyl wall looks awfully squared off. Looks like the bottom of the piston was knocking into it over and over. But it's hard to know. It's also very possible your piston had too much clearance so that skirt was whacking against the bore. Too much Wear or too much clearance can cause that.
I mean, anything can happen with wear and big power, and a window creates a weaker spot but most times the piston would be destroyed with a window or not. Slapping in the bore fucks shit up.
Btw, A massive window is only really needed on cyl reed setups without a dedicated boost port in the cases, like this treats reed. Otherwise you're severely limiting flow. (edited)
  Playing with puchTopic by: Totally normal JBOT Totally normal JBOT 02/06/19 09:26PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/06/19 09:58PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/06/19 10:01PM
  Re: Playing with puchRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 02/06/19 11:01PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/06/19 11:25PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/06/19 11:32PM
  Re: Playing with puchRe: Adam Smith Adam Smith 02/07/19 06:47AM
  Re: Playing with puchRe: Alan Jackson Alan Jackson 02/07/19 05:46AM
  Re: Playing with puchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/07/19 09:40AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 11:16AM
  Re: Playing with puchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/07/19 12:49PM
  Re: Playing with puchRe: Alex hernandez Alex hernandez 02/07/19 03:34PM
  Re: Playing with puchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/07/19 03:56PM
  Re: Playing with puchRe: Probably Fred Probably Fred 02/07/19 04:08PM
  Re: Playing with puchRe: Chris Straub Chris Straub 02/07/19 03:25PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 08:18PM
  Re: Playing with puchRe: Chris Straub Chris Straub 02/08/19 02:12AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 02:28AM
  Re: Playing with puchRe: Chöschi21 C.K. Chöschi21 C.K. 02/07/19 04:27PM
  Re: Playing with puchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/07/19 04:36PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 08:34PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 09:08PM
  Re: Playing with puchRe: Kevin Bishop Kevin Bishop 02/07/19 05:40PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 08:22PM
  Re: Playing with puchRe: patrick stover patrick stover 02/07/19 05:47PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 08:25PM
  Re: Playing with puchRe: Kevin Bishop Kevin Bishop 02/07/19 09:36PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 09:42PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 10:31PM
  Re: Playing with puchRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 02/07/19 10:36PM
  Re: Playing with puchRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 02/07/19 10:40PM
  Re: Playing with puchRe: Anthony Moody Anthony Moody 02/08/19 08:32PM
  Re: Playing with puchRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 02/08/19 09:49PM
  Re: Playing with puchRe: Anthony Moody Anthony Moody 02/09/19 04:54AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 10:50PM
  Re: Playing with puchRe: Kevin Bishop Kevin Bishop 02/07/19 10:40PM
  Re: Playing with puchRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 02/07/19 10:52PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 11:04PM
  Re: Playing with puchRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 02/07/19 11:08PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 11:17PM
  Re: Playing with puchRe: Thomas TPRF Thomas TPRF 02/08/19 12:03AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 01:01AM
  Re: Playing with puchRe: Thomas TPRF Thomas TPRF 02/08/19 11:24AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 11:42AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 11:49AM
  Re: Playing with puchRe: Graham Motzing Graham Motzing 02/08/19 11:51AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 11:56AM
  Re: Playing with puchRe: Graham Motzing Graham Motzing 02/08/19 12:53PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 01:02PM
  Re: Playing with puchRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 02/08/19 02:40PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 04:38PM
  Re: Playing with puchRe: Graham Motzing Graham Motzing 02/09/19 09:32AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 11:54AM
  Re: Playing with puchRe: Thomas TPRF Thomas TPRF 02/09/19 11:42AM
  Re: Playing with puchRe: niklaus _ niklaus _ 02/08/19 02:19AM
  Re: Playing with puchRe: Dirty30 Dillon Dirty30 Dillon 02/08/19 09:41AM
  Re: Playing with puchRe: Alex hernandez Alex hernandez 02/08/19 11:22AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 11:32AM
  Re: Playing with puchRe: Graham Motzing Graham Motzing 02/08/19 11:45AM
  Re: Playing with puchRe: Alan Jackson Alan Jackson 02/08/19 03:49PM
  Re: Playing with puchRe: P D P D 02/09/19 12:15PM
  Re: Playing with puchRe: Satan Lucifer Satan Lucifer 11/01/22 06:38PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 11/01/22 08:36PM
