Re: Playing with puch
Totally normal JBOT /
Maybe I do something different, idk. I always only cut the piston thru the thin parts, leaving the thicker 4 corner supports intact.
I don't leave thin skirts long, better to cut a lot away, still get the same flow.
I rarely take the secondhand knowledge of other folks failures into account anymore, because so many things can happen in a ripper 2t that can cause problems, usually it's the builders fault. I've never spit a wrist pin clip either. Because I use the proper clips (never use the double mustache pos) and always retension them a lot before install.
I'll take my lumps if I fuck up, which I do a lot....but so many problems can be avoided if one runs a buttery piston thru a buttery cyl, with low temps and good oil. Now I'm hungry
  Playing with puchTopic by: Totally normal JBOT Totally normal JBOT 02/06/19 09:26PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/06/19 09:58PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/06/19 10:01PM
  Re: Playing with puchRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 02/06/19 11:01PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/06/19 11:25PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/06/19 11:32PM
  Re: Playing with puchRe: Adam Smith Adam Smith 02/07/19 06:47AM
  Re: Playing with puchRe: Alan Jackson Alan Jackson 02/07/19 05:46AM
  Re: Playing with puchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/07/19 09:40AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 11:16AM
  Re: Playing with puchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/07/19 12:49PM
  Re: Playing with puchRe: Alex hernandez Alex hernandez 02/07/19 03:34PM
  Re: Playing with puchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/07/19 03:56PM
  Re: Playing with puchRe: Probably Fred Probably Fred 02/07/19 04:08PM
  Re: Playing with puchRe: Chris Straub Chris Straub 02/07/19 03:25PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 08:18PM
  Re: Playing with puchRe: Chris Straub Chris Straub 02/08/19 02:12AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 02:28AM
  Re: Playing with puchRe: Chöschi21 C.K. Chöschi21 C.K. 02/07/19 04:27PM
  Re: Playing with puchRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/07/19 04:36PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 08:34PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 09:08PM
  Re: Playing with puchRe: Kevin Bishop Kevin Bishop 02/07/19 05:40PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 08:22PM
  Re: Playing with puchRe: patrick stover patrick stover 02/07/19 05:47PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 08:25PM
  Re: Playing with puchRe: Kevin Bishop Kevin Bishop 02/07/19 09:36PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 09:42PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 10:31PM
  Re: Playing with puchRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 02/07/19 10:36PM
  Re: Playing with puchRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 02/07/19 10:40PM
  Re: Playing with puchRe: Anthony Moody Anthony Moody 02/08/19 08:32PM
  Re: Playing with puchRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 02/08/19 09:49PM
  Re: Playing with puchRe: Anthony Moody Anthony Moody 02/09/19 04:54AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 10:50PM
  Re: Playing with puchRe: Kevin Bishop Kevin Bishop 02/07/19 10:40PM
  Re: Playing with puchRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 02/07/19 10:52PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 11:04PM
  Re: Playing with puchRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 02/07/19 11:08PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/07/19 11:17PM
  Re: Playing with puchRe: Thomas TPRF Thomas TPRF 02/08/19 12:03AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 01:01AM
  Re: Playing with puchRe: Thomas TPRF Thomas TPRF 02/08/19 11:24AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 11:42AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 11:49AM
  Re: Playing with puchRe: Graham Motzing Graham Motzing 02/08/19 11:51AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 11:56AM
  Re: Playing with puchRe: Graham Motzing Graham Motzing 02/08/19 12:53PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 01:02PM
  Re: Playing with puchRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 02/08/19 02:40PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 04:38PM
  Re: Playing with puchRe: Graham Motzing Graham Motzing 02/09/19 09:32AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 11:54AM
  Re: Playing with puchRe: Thomas TPRF Thomas TPRF 02/09/19 11:42AM
  Re: Playing with puchRe: niklaus _ niklaus _ 02/08/19 02:19AM
  Re: Playing with puchRe: Dirty30 Dillon Dirty30 Dillon 02/08/19 09:41AM
  Re: Playing with puchRe: Alex hernandez Alex hernandez 02/08/19 11:22AM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 02/08/19 11:32AM
  Re: Playing with puchRe: Graham Motzing Graham Motzing 02/08/19 11:45AM
  Re: Playing with puchRe: Alan Jackson Alan Jackson 02/08/19 03:49PM
  Re: Playing with puchRe: P D P D 02/09/19 12:15PM
  Re: Playing with puchRe: Satan Lucifer Satan Lucifer 11/01/22 06:38PM
  Re: Playing with puchRe: Totally normal JBOT Totally normal JBOT 11/01/22 08:36PM
