Re: Vespa Grande Head Leak
Dirty30 Dillon /
Did you buy the DR used? An over-aggressive porter could blast through the third stud in the exhaust and cause all sorts of issues.
Barring that, I have lapped decomps and had them not work out.
But I will agree with Graham, putting a double nut on the decomp hardware removes that common problem with the bottom head bolt coming lose after heat cycling
