Tomos Standard increase speed
Mikael Lundin /
Hi All
I am about to buy a Tomos Standard moped that does 25 km/h as shipped. http://www.tomos.si/en/moped/standard/
I am not sure if they are blocked from higher speed by electronics or my motor/exhaust or other reason. Does anyone know?
I would like it to do like 35-45 km/h, I dont need alot of power since I only go to and from work schich is kind of flat. But I want more speed.
Thank in advance for all tips :-)
Mikael
Re: Tomos Standard increase speed
Change out your cylinder, piston and maybe the head with 45km/h parts. I believe the 25km/h version is only restricted by the top end, nothing else. Just waiting for some Euro pedders to give a more reliable answer.
just buy the 45/km one. whats the price difference.? by specs it looks restricted by carb(smaller), compression(lower) and likely gearing, not sure about electrics. read wiki tomos entry if u wanna do 60km on a pretty stock tomos.
Probably Fred /
What good is a motorbike that goes 25 KMH (15mph) when you could can run or pedal a bicycle faster than that ?
Get the 45km model or change the carb, intake, exhaust and tuning to 45km specs
45km is useless as far as motorbike is concerned too for most 10-15 speed people powered bikes can go fast as that (26mph)
Why are there two versions, 25kph and 45kph?
Is it a license question or a taxation question?
Mike
Mikael Lundin /
There are reasons why I dont want the 45 km/h moped even thought they cost the same:
* It has to be registered - money
* I cant drive on bikeroads so only car-roads where they drive 60-70..I pile up traffic
* Insurance is like 20 times more expensive for 45 vs 25 for some reason
* I want to drive on bikelanes
I have a electric bike but im injured badly in my pelvis and hip so I cant ride it so this is instead of my bike until I get better. I want to go on bikelanes since it is alot shorter and no traffic.
45 moped also demands a licence, I have a motorcycle license so no problem for me though.
Im not sure where to get a reliable answer regarding where it is restriced so it does only 25 since it is probably the same moped as the 45 one in general.
Dirty30 Dillon /
It is a mechanical restriction via intake.carb sizing, cylinder porting, and most importantly gearing.
Either of these will solve your speed problems i believe. You can do it cheaper, but these include everything you'd need...other than a few carb Jets maybe.
https://www.treatland.tv/tomos-A35-70cc-alukit-party-supreme-version-2-p/tomos-a35-party-supreme-2.htm
https://www.treatland.tv/tomos-A35-70cc-alukit-party-supreme-p/tomos-a35-party-supreme.htm
Mikael Lundin /
With gearing, do you mean the actual gearbox or the number of cogs in the back and front?
