Re: porting picts and success and failures
Chöschi21 C.K. /
I suggest to you that you should start with either first porting a Cylinder with cast iron walls or just try removing material on an old (at best non usable) alu-cylinder with Nicasil plating, Nicasil likes to chip off, so you should get comfortable with it first.
Stock aluminium Puch cylinders aren't Nicasil Plated, their Plating doesn't chip of as easly so if you want to try some porting for your Tomos maybe a stock Puch cylinder would be an idea as long as you can modify an intake and exhaust to fit.
  porting picts and success and failuresTopic by: pat splat pat splat 02/03/19 02:33PM
  Re: porting picts and success and failuresRe: pat splat pat splat 02/03/19 02:36PM
  Re: porting picts and success and failuresRe: Adam Smith Adam Smith 02/03/19 03:14PM
  Re: porting picts and success and failuresRe: Totally normal JBOT Totally normal JBOT 02/03/19 10:31PM
  Re: porting picts and success and failuresRe: patrick stover patrick stover 02/03/19 11:00PM
  Re: porting picts and success and failuresRe: Seth B Seth B 02/03/19 03:34PM
  Re: porting picts and success and failuresRe: Adam Smith Adam Smith 02/03/19 03:45PM
  Re: porting picts and success and failuresRe: Daniel '' Daniel '' 02/03/19 03:53PM
  Re: porting picts and success and failuresRe: Alan Jackson Alan Jackson 02/07/19 06:48AM
  Re: porting picts and success and failuresRe: Totally normal JBOT Totally normal JBOT 02/07/19 11:27AM
  Re: porting picts and success and failuresRe: Alan Jackson Alan Jackson 02/08/19 03:53PM
  Re: porting picts and success and failuresRe: Totally normal JBOT Totally normal JBOT 02/08/19 04:45PM
  Re: porting picts and success and failuresRe: Alan Jackson Alan Jackson 02/08/19 05:22PM
  Re: porting picts and success and failuresRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 02/08/19 09:55PM
  Re: porting picts and success and failuresRe: Chöschi21 C.K. Chöschi21 C.K. 02/09/19 09:44AM
  Re: porting picts and success and failuresRe: Totally normal JBOT Totally normal JBOT 02/09/19 11:13AM
  Re: porting picts and success and failuresRe: Chöschi21 C.K. Chöschi21 C.K. 02/09/19 11:19AM
  Re: porting picts and success and failuresRe: Totally normal JBOT Totally normal JBOT 02/09/19 12:46PM
  Re: porting picts and success and failuresRe: Totally normal JBOT Totally normal JBOT 02/09/19 12:47PM
  Re: porting picts and success and failuresRe: Chöschi21 C.K. Chöschi21 C.K. 02/09/19 01:09PM
  Re: porting picts and success and failuresRe: Totally normal JBOT Totally normal JBOT 02/09/19 01:40PM
  Re: porting picts and success and failuresRe: Chöschi21 C.K. Chöschi21 C.K. 02/09/19 01:56PM
  Re: porting picts and success and failuresRe: Totally normal JBOT Totally normal JBOT 02/09/19 02:33PM
  Re: porting picts and success and failuresRe: Chöschi21 C.K. Chöschi21 C.K. 02/09/19 09:47AM
  Re: porting picts and success and failuresRe: Chöschi21 C.K. Chöschi21 C.K. 02/09/19 02:46PM
  Re: porting picts and success and failuresRe: Totally normal JBOT Totally normal JBOT 02/09/19 02:52PM
  Re: porting picts and success and failuresRe: Chöschi21 C.K. Chöschi21 C.K. 02/09/19 03:12PM
  Re: porting picts and success and failuresRe: Totally normal JBOT Totally normal JBOT 02/09/19 05:33PM
  Re: porting picts and success and failuresRe: Chöschi21 C.K. Chöschi21 C.K. 02/09/19 06:00PM
  Re: porting picts and success and failuresRe: pat splat pat splat 02/10/19 04:49PM
  Re: porting picts and success and failuresRe: sketch mo sketch mo 02/11/19 08:50PM
  Re: porting picts and success and failuresRe: Chöschi21 C.K. Chöschi21 C.K. 02/12/19 04:19AM
  Re: porting picts and success and failuresRe: Dirty30 Dillon Dirty30 Dillon 02/12/19 07:21AM
  Re: porting picts and success and failuresRe: Chöschi21 C.K. Chöschi21 C.K. 02/12/19 08:07AM
  Re: porting picts and success and failuresRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 02/12/19 11:35AM
  Re: porting picts and success and failuresRe: Adam Smith Adam Smith 02/12/19 10:43AM
  Re: porting picts and success and failuresRe: Seth B Seth B 02/12/19 05:10PM
  Re: porting picts and success and failuresRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 02/12/19 05:50PM
