Re: Transval Retarding CDI Box for Motobecane
Jarod V. /
So the Scrappy Dog site doesn't offer a standalone CDI box any more, but with a little research it looks like this is the same one, does this look correct to you?
https://www.ebay.com/itm/5-Wire-CDI-Igniter-for-Yamaha-JOG50-JOG90-Zuma-50-Vento-Triton-R4-50cc-ATV/132789716880?hash=item1eeae24790:g:ivMAAOSwDaBcAoHp:rk:2:pf:1
Also, what's the correlation between degrees and mm's btdc? it seems like people are setting these boxes around 1.5-1.6mm btdc base timing and they end up retarding to around 1.0mm, which is what I want mine set at. Does that sound correct? (edited)
