Re: Gilardoni 47mm reed kit - questions
Alan Jackson /
just wanted to hear what other people had found re ignition timing
and at what revs the power was at and if the gila ports were any good as is.
im newish to the moped tuning scene and the bike can only hit 50mph maxing out in top gear. (taller gears in post) im running at .8mm timing so that might be holding it back for midrange power.
(puch m50 sports - like a 4 speed monza)
ive found you have to overthink if you want to make a pipe that works,
plus overthinking is my hobby.
my cylinder is angled at about 45 degrees unlike the flat maxi's so im a bit restricted for off the shelf pipes unless I wanna do some hacking/welding. I do have a 30mm od header pipe fitted so could hack and fit something to that.
ill have a look at the pipes you mention.
edit
the tomos techno Estoril comes out on the wrong side for my bike mine prefers to the left. (edited)
