Re: Gilardoni 47mm reed kit - questions
Graham Motzing /
even a pretty basic setup on that kit will push a moped well into the 50 mph range. The MLM pipes are huge and blasty, but the Tomos Tecno Estoril will be plenty of pipe to break 50.
the compression and pipe will dictate the timing, i dunno what kinda bike you're putting it on, monza? MS50? good rule of thumb is 18 degrees for starters and see how she likes it, watch cylinder temp gauge if you have to and adjust accordingly.
haven't ever port mapped one of these to know what you're talking about but they make good power up to about 8-9k depending on the pipe and respond well to a little exhaust porting.
sounds like you're overthinking it.
