Re: Jetting needed with change of engine oil? (2 stroke)
Ryan . /
To me anyway it seemed like he was asking if the different viscosity of the mix would affect flow rate through the orifice of the jet and cause changes in air fuel ratio due to a thicker oil lowering the volume of mix delivered over a set time.
If this was actually the question then I could see the possibility of there being a difference, but I also see the possibility of that difference being so negligible that it means nothing.
