Pipe question
The I’m modding this pipe to fit my grande when I cut it apart I noticed this grated piece of sheetmetal welded in the pipe. What’s it for? Should I keep it or remove it?
Re: Pipe question
Dirty30 Dillon /
It really common in scooter pipes to baffle with perforated cones or sections of cones.
In this case, I think it relates to avoiding resonance in the material, and is probably not worth removing.
Re: Pipe question
I’ll preface this with saying I’m only repeating what I’ve read......
apparently sometimes the perforated baffles help widen the power band as above a certain gas velocity they have less of an effect?
Sounds iffy to me, but I don’t have the materials or time handy to test the idea.
Re: Pipe question
Dirty30 Dillon /
> the idea.
I'm going to second Thomas on this. If you look at pipe dynos you can see that the ones with the perforated cones have much better over-rev
Re: Pipe question
Thanks for the input, I’ll leave it in there. (edited)
Re: Pipe question
That's cool to know, I assumed it was in there to meet regulations since you tend to see them in the restricted Euro market pipes. Like a band-aid to give it a li'l more quiet.
I just cut that pipe up for a Honda aero 80, sounds great and feels like it will be a ripper once it's dialed in. I'm sure I'll be buying another one soon, great hack and weld pipe at an awesome price.
Re: Pipe question
The 'grates' also arrest sparks very effectively . ;)
Re: Pipe question
Probably Fred /
I guess I’m just old school, I disagree with anything that’s put inside of a expansion chamber, I remove everything, I want it to reflect back the pulses the way a chamber is suppose to,
I don’t care if something is a little louder or tinnie sounding in a chamber, two stroke noises make me smile
Re: Pipe question
That's not old school thinking .
The grates we're seeing in this thread seem to be housed in the baffle/silencer , which comes into play after the expansion chamber . So , it shouldn't effect the harmonics of the chamber very much , if at all .
Re: Pipe question
The grated piece is welded to the convergent cone in the expansion chamber, you can see the heat marks from the weld on the treats pic. (edited)
Re: Pipe question
Wouldn't that put the grate right against the side of the cone ?
Maybe I'm missing something ?
Re: Pipe question
Yeah it’s welded against the cone, only on one side of the cone. So half of the cone has the grate. The pic is taken from the inlet side. Here’s what was cut off. (edited)
Re: Pipe question
I must be old school too , Ken . ;)
Who'da thunk it ? LOL
Learn something new , every day .
