> Michael Forrest Wrote:
> even when the beginning of the taper is lower than the top of the narrow
> part of the atomizer there is fuel flow thru that small area between the
> needle and the atomizer. I think the atomizer diameter is usually about
> .15mm bigger than the fat part of the needle.
i understand that but the needles are the same diameter above the taper 2.5MM
( actually measure 2.48mm) so you wouldn't think theyd make any difference when needle is below start of taper.
but it has.
