Re: Tomos 4-pole cdi setup on an e50
todd amundson /
Did this yesterday. Shawn at Myron’s let it go for pretty cheap. The coil said nothing on it but looks Permakit. Clockwise rotation, found where it fired, and set timing.
Only problem is setting up for pull starting. If you make tangs that come off the flywheel, you need to make damn sure a puller will still screw on there after welding or bolting.
Anywho, works on E50 no problem
