As you can see the frame brace needed to go so I got a nice chunk of flat stock and replaced it a little further back.
while I was checking that out decided to fix the cracked engine mount that typically happened to variants (don’t forget to drill a small hole at the end of the crack).
should be better now but we shall see once I take it out.
well that’s it for now, will update as soon as I get time to dick with it again.
