Re: Puch 44mm(63ccm) Airsal
Chöschi21 C.K. /
Bottom end Bearing of the Conrod has noticable play in it...
Back and fourth or in line with the conrod?
Chöschi21 C.K. /
In line, front to back, side to side also, but i know that's normal.
Chöschi21 C.K. /
Going to get a Swiing Crankshaft, how much Bearing play should i have for it? Are C4 Bearings okay, or should i rahter get C3?
c3 bearings are just fine. If the OEM used C3, better to use it yourself as well.
Also, if your rod has in and out play inline with the rod, it's junk and needs replacing.
Chöschi21 C.K. /
Crank laying on my Workbench, C3 Bearings, rebuilding the whole Engine, wanted to get a Supermaxi or at least a 4 Bearing Block but can't find one right now, gonna continue my Project stuff here:
https://www.mopedarmy.com/forums/read.php?1,4254534
Richard Eberline /
Broken ring and a scuff on your piston, exhaust side.
Chöschi21 C.K. /
What?
