2tRe: POST YOUR BUILD
Overpriced Parts /
10+ year-old e50 build, mid upper 50smph, puch Polni 64cc kit,15mm bing, points ignition 14.25° before top dead center timing, tuned clutch with thing springs,
Build has 18k mph on original cylinder 30 k on bottom end in stock OEM bearings and seals but with preventative maintenance ring/piston changes,
And no junk type F fluid but 5w20 synthetic motor oil in tranny,
So many people put a kit on a bike run it for a few thousand miles then blow it up!
But that’s not me! nikasa/chrome bore cylinders to not go out of around like cast iron lined ones, you can get 20 K miles out of a kit if you change rings and pistons and you’re supposed with mileage recommendations,
I mean I keep up with 90-100 cc enduro bikes on streets (not dirt though) with a 40 year old maxi that has a 64cc puch Polini kit that was built 12 seasons ago,
there are so many dumies out here that don’t understand , pull your cylinder and check clearances 3 to 5kmi and change the parts instead of buying kit after kit after kit!
  POST YOUR BUILDTopic by: Andrew M Andrew M 10/11/18 03:41PM
  Re: POST YOUR BUILDRe: Andrew M Andrew M 10/11/18 04:06PM
  Re: POST YOUR BUILDRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/11/18 04:12PM
  Re: POST YOUR BUILDRe: todd amundson todd amundson 10/11/18 05:02PM
  Re: POST YOUR BUILDRe: Dirty30 Dillon Dirty30 Dillon 10/11/18 05:27PM
  Re: POST YOUR BUILDRe: Alex hernandez Alex hernandez 10/11/18 07:20PM
  Re: POST YOUR BUILDRe: - Joe - - Joe - 10/11/18 10:31PM
  2tRe: POST YOUR BUILDRe: Overpriced Parts Overpriced Parts 10/11/18 05:47PM
  Re: POST YOUR BUILDRe: EH FCC of the QCB EH FCC of the QCB 10/11/18 06:12PM
  Re: POST YOUR BUILDRe: Erik Thalman Erik Thalman 10/11/18 09:11PM
  Re: POST YOUR BUILDRe: Overpriced Parts Overpriced Parts 10/12/18 05:28PM
  Re: POST YOUR BUILDRe: Jack Rutherford Jack Rutherford 10/12/18 09:54PM
  Re: POST YOUR BUILDRe: Tim R Tim R 10/12/18 08:05AM
  Re: POST YOUR BUILDRe: alex . alex . 10/12/18 11:45PM
  Re: POST YOUR BUILDRe: Anonymous User Anonymous User 10/13/18 12:55AM
  Re: POST YOUR BUILDRe: alex . alex . 10/15/18 12:41AM
  Re: POST YOUR BUILDRe: Marc Friedman Marc Friedman 05/25/19 01:27AM
  Re: POST YOUR BUILDRe: Jonathan Eaton Jonathan Eaton 10/12/18 12:26PM
  Re: POST YOUR BUILDRe: Jn Ttro Jn Ttro 10/12/18 01:16PM
  Re: POST YOUR BUILDRe: Ollie Tabooger Ollie Tabooger 10/13/18 02:21AM
  Re: POST YOUR BUILDRe: P D P D 10/13/18 10:54AM
  Re: POST YOUR BUILDRe: Gabe Mustane Gabe Mustane 10/14/18 06:21AM
  Re: POST YOUR BUILDRe: P D P D 10/14/18 10:46AM
  Re: POST YOUR BUILDRe: Gabe Mustane Gabe Mustane 10/14/18 10:51AM
  Re: POST YOUR BUILDRe: P D P D 10/14/18 11:21AM
  Re: POST YOUR BUILDRe: Gabe Mustane Gabe Mustane 10/14/18 11:45AM
  Re: POST YOUR BUILDRe: P D P D 10/14/18 12:15PM
  Re: POST YOUR BUILDRe: Gabe Mustane Gabe Mustane 10/14/18 12:58PM
  Re: POST YOUR BUILDRe: P D P D 10/14/18 01:41PM
  Re: POST YOUR BUILDRe: Jonathan Feldman Jonathan Feldman 10/14/18 03:07PM
  Re: POST YOUR BUILDRe: Gabe Mustane Gabe Mustane 10/14/18 06:40PM
  Re: POST YOUR BUILDRe: EH FCC of the QCB EH FCC of the QCB 10/14/18 08:05PM
  Re: POST YOUR BUILDRe: alex ganz alex ganz 10/15/18 01:20PM
  Re: POST YOUR BUILDRe: Anonymous User Anonymous User 10/16/18 10:51AM
  Re: POST YOUR BUILDRe: Bob Selby Bob Selby 10/14/18 06:26PM
  Re: POST YOUR BUILDRe: Mitch Bristol Mitch Bristol 10/16/18 09:24AM
  Re: POST YOUR BUILDRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/16/18 11:40AM
  Re: POST YOUR BUILDRe: Adam Smith Adam Smith 05/25/19 07:09AM
  Re: POST YOUR BUILDRe: Josiah Radebaugh Josiah Radebaugh 05/25/19 10:47PM
  Re: POST YOUR BUILDRe: Marc Friedman Marc Friedman 05/25/19 11:38PM
  Re: POST YOUR BUILDRe: -Summerai - Shong -Summerai - Shong 06/01/19 07:55AM
