POST YOUR BUILD
This is a thread to post your set up, moped type and year, and top speeds achieved with current set up
Re: POST YOUR BUILD
Right now on my puch 1978 Free Spirit I have:
Airsal 70cc kit
High comp head
12mm bing carb
Stock intake
Fuego Boss exhaust
Using 92 Octane fuel
Top speed recently: 37 mph
Re: POST YOUR BUILD
2077 puch maxi s
Airsal
Uranium injected
Running only 93oct. uranium
Top speed: the future
Re: POST YOUR BUILD
todd amundson /
1900 JC Penny Pinto
Metra 80
Welded E50
Shitty gas only
56 mph
Re: POST YOUR BUILD
Dirty30 Dillon /
There is a tuning spreadsheet exactly for this purpose
2tRe: POST YOUR BUILD
Overpriced Parts /
10+ year-old e50 build, mid upper 50smph, puch Polni 64cc kit,15mm bing, points ignition 14.25° before top dead center timing, tuned clutch with thing springs,
Build has 18k mph on original cylinder 30 k on bottom end in stock OEM bearings and seals but with preventative maintenance ring/piston changes,
And no junk type F fluid but 5w20 synthetic motor oil in tranny,
So many people put a kit on a bike run it for a few thousand miles then blow it up!
But that’s not me! nikasa/chrome bore cylinders to not go out of around like cast iron lined ones, you can get 20 K miles out of a kit if you change rings and pistons and you’re supposed with mileage recommendations,
I mean I keep up with 90-100 cc enduro bikes on streets (not dirt though) with a 40 year old maxi that has a 64cc puch Polini kit that was built 12 seasons ago,
there are so many dumies out here that don’t understand , pull your cylinder and check clearances 3 to 5kmi and change the parts instead of buying kit after kit after kit!
Re: POST YOUR BUILD
@todd. Shitty gas only
Hahahaha
Re: POST YOUR BUILD
This is way better than the spreadsheet keep posting!
Sick pinto with the metra kit. That kicks ass thanks for posting the case bore for us to see.
Re: POST YOUR BUILD
1980 Puch magnum
E50
Polini 64
Hi hi comp head
Stock 2 pedal
15 Bing
Jammer v6.3 soft springs
Tecno estoril with cone
16x45
Hits 45(edited)
Re: POST YOUR BUILD
1980 Vespa grande
Malossi 43mm 64cc
Custom machined head for low temps
Stock crank cut
13.13 carb, malossi high flow filter
Proma pipe
Modded gy6 variator
Custom clutch cheeks for full variation
Top speed 45mph
Re: POST YOUR BUILD
87 derbi variant
Airsal 75
Tjt variator with treats plate...needs to go lighter
Yellow contra...needs to go weaker
Vm18 with 4 pedal reed block
Jormans pipe
Hpi mini
Top speed 55 ripping my arms off
Re: POST YOUR BUILD
Jonathan Eaton /
1980 Garelli SSXL
46mm Polini
Stock head
17.5 PHBG (Clone) on Treats Garelli/Minarelli cast 19mm intake
(Pic still shows the stock SHA 14.12)
Hacked Puch Estoril pipe
Stock ignition, slightly retarded from factory marks
11 x 32 Gearing
Tops out at 48
(edited)
Re: POST YOUR BUILD
99 turdmos targa lx
A35
44mm airsal, no porting or case match
Puch hicomp head
Mlm intake
16.16 Sha
Tecno estoril
Dos cycles 1st gear clutch shoes
27x22 gears
Stock crank
Stock ignition
Stock reeds
Treats stickers
53mph full tuck level ground
Re: POST YOUR BUILD
Overpriced Parts /
> Erik Thalman Wrote:
> https://imageshack.com/a/img922/4801/Iinr0f.jpg
> 1980 Puch magnum
> E50
> Polini 64
> Hi hi comp head
> Stock 2 pedal
> 15 Bing
> 16x45
> Hits 45
Stock polini reed is only 1 pedal
Re: POST YOUR BUILD
Jack Rutherford /
Honda NCU50 Hybrid Express
Temporary gas tanks;
Iowa NU50 engine, disinterred from its grave, courtesy of Jimmy Cincinnati;
12 volt conversion;
SHA clone carb;
People's pipe;
gy6 clutch;
bx31;
grey contra - yellow clutch springs;
super cushy rear end;
and loads of fun.
37 mph right now and only getting faster.(edited)
Re: POST YOUR BUILD
1978 bravo
64cc polini race ported
Modified Mazucelli
Speed cases
13 sha
Calibratta
Malossi gears
Kinetic cdi
Polini varo
US clutch lightened with dio springs
90mm cnc cheeks
Super nice subframe pair with hydros for safe stable riding
58 flats 64 on a hill once. Eats uphill shit alive
Re: POST YOUR BUILD
That is a sick build!
Re: POST YOUR BUILD
1981 Suzuki FA50
70 mph
Re: POST YOUR BUILD
LOL . ^
Re: POST YOUR BUILD
Gabe Mustane /
70cc K-star 18x45 gearing
17mm bing clone
Unstuffed crank
Stock two shoe clutch w/ESO springs
Case matched
45mph and great on hills
Re: POST YOUR BUILD
> 17mm bing clone
> Unstuffed crank
> Case matched
What are the square tabs on your lower fork tubes ?
And , why isn't there a single soul on the beach ? ;)
Re: POST YOUR BUILD
Gabe Mustane /
Tabs are for a fork brace I haven't finished. Trying to bend half inch steel isn't as easy as I thought it would be...
I ran my bike in the nude to scare everyone away so I could get a nice picture! HA!
Nah, it was a cold evening and the tourists weren't having it.
Re: POST YOUR BUILD
> picture! HA!
Maybe try map gas on that steel . Get it reddish and you'll be able to place it at will .
I figured there probably aren't many tourists left to pollute the beach .
I've been along that beach a few times . I use to take a break there when on my photo route back in the 90s .
Re: POST YOUR BUILD
Gabe Mustane /
> place it at will .
I've got a Oxy/Acetylene torch at work I'm going to try and get it cherry, hopefully it'll bend nice.
Really you've been through lil ol Manistee on Michigan's west coast? That's pretty cool!
Re: POST YOUR BUILD
> That's pretty cool!
That oxy set up will get 'er done .
And , yeah , the West side of Michigan was my stomping ground for most of my life . I was born in the back of a grocery store , in a little farm town , SW of GR . Grew up 6 miles from there and after the USAF , lived in NE GR for about 20 years .
Manistee is the place I rec'd my last traffic citation . 35 in a 25 . :( LOL
Re: POST YOUR BUILD
Gabe Mustane /
> LOL
Oh yeah, back in the day when manistee had a state trooper post, tribal, sheriff, and city posts. Bound to get a ticket for something!!
Thanks for your service. I spent some time in the Army.
Re: POST YOUR BUILD
You're welcome , and , the same to you . :)
Re: POST YOUR BUILD
Jonathan Feldman /
Peugeot 103SP
Modded stock variator / le partie / 50cc gilardoni cylinder / hack n weld PMA pipe / 17mm Amal
Somewhere in the mid 40s depending how it's feeling.
Starting to tear it apart meow for full blaster stats. Viva la resistance!
Re: POST YOUR BUILD
Right now all I have is that kickstart motor I got from Will J. from the Netherlands last week...It came with 1988 reverse gears and 3-shoe. I put a super suffy, Nachi bearings, Airsal 45mm and 6-wire magneto on it...
Re: POST YOUR BUILD
Gabe Mustane /
> Jonathan Feldman Wrote:
> Peugeot 103SP
> resistance!
Something about Peugeot’s... I need one in my life. Cool bike man.
