Re: Yamaha RD60 Megathread (Shifty50 content)
Joel P /
Yep. It rides really quite nice. I may get slightly softer springs for the front but it's marginally heavier than the old steel everything forks and rims and I can run modern 17" rubber.
The motor is quite hopped up. KTM 125 rod with a KX100 Piston, bored .5 over. Port map baseline is the same as MX100 of that year (Factory 16hp) Then I tweaked it further. Big Reeds and a KX100 28mm Keihin with a pipe I designed specifically for that motor.
My motor and your motor share quite a few similarities. You can do all sorts of stock looking big bore and weird engine combinations with all the engines of that era. It depends if you have the long lower mount or the short one but if you can jam 125cc cases in the frame and then you can put up to a 175 cylinder on there and make a ripper.
You can see it move for the first time ever on it's own in 20 years in this video. Unfortunately the clutch was slipping because I had the lower adjuster too tight at the time.
> Ted Kenny Wrote:
> well that’s very cool .. lot of front end for a tilla ... but i’m
> impressed...have you got it out and run it ...
  Yamaha RD60 Megathread (Shifty50 content)Topic by: Gerry F Gerry F 09/27/18 02:00AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Gerry F Gerry F 09/28/18 02:07PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Gerry F Gerry F 10/11/18 10:15AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Gerry F Gerry F 10/12/18 11:13PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 08/07/19 08:28PM
  I have one of thoseRe: Phil M Phil M 08/08/19 12:10PM
  Re: I have one of thoseRe: Bonnie Blake Bonnie Blake 10/01/19 09:56AM
  Re: I have one of thoseRe: Josiah Radebaugh Josiah Radebaugh 10/01/19 01:17PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: William Johnson William Johnson 08/08/19 01:48PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Gerry F Gerry F 08/08/19 02:48PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: punkrock randy punkrock randy 08/11/19 01:07PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Mikey Antonakakis Mikey Antonakakis 08/13/19 01:21PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: William Johnson William Johnson 08/13/19 02:47PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Josiah Radebaugh Josiah Radebaugh 08/11/19 01:19PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: William Johnson William Johnson 08/12/19 04:08PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Chris Szuba Chris Szuba 08/13/19 08:28AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Phil M Phil M 08/13/19 03:42PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Dirty30 Dillon Dirty30 Dillon 08/13/19 03:47PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Gerry F Gerry F 10/09/19 12:27PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/27/19 08:39PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 12/31/19 09:29PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 01/01/20 04:16PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: P D P D 01/01/20 04:28PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Gerry F Gerry F 01/02/20 12:24AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 01/02/20 05:35PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Born to be WillD Born to be WillD 01/03/20 12:13PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Kurt Van Luven Kurt Van Luven 02/22/20 06:38AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 01/19/20 09:54PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 01/27/20 09:00PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Kim Jong illest Kim Jong illest 01/28/20 07:23AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 02/05/20 08:30PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 02/05/20 09:05PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 02/05/20 09:26PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 02/06/20 10:11PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 02/06/20 10:21PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 02/14/20 08:11PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 02/16/20 06:42PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Dirty30 Dillon Dirty30 Dillon 02/17/20 01:13PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Joel P Joel P 02/21/20 10:30PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Kim Jong illest Kim Jong illest 02/20/20 08:47PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 02/22/20 06:46PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Joel P Joel P 02/23/20 12:22PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 02/22/20 06:55PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 02/22/20 07:33PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 03/04/20 06:47PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 03/04/20 06:51PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 03/04/20 06:57PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Daniel '' Daniel '' 03/04/20 07:24PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 03/05/20 07:48PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 03/05/20 07:50PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 04/09/20 10:16PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Eric Nygard Eric Nygard 04/13/20 12:56PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 04/21/20 11:04PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Gerry F Gerry F 04/22/20 12:46AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Joel P Joel P 04/24/20 01:10PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 04/26/20 07:07PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 04/26/20 07:13PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 04/26/20 07:18PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 05/03/20 11:57AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ryan Graeme Ryan Graeme 05/03/20 03:32PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Joel P Joel P 05/03/20 08:06PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Jesse Stephenson Jesse Stephenson 05/04/20 01:24PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Onyman T Onyman T 05/06/20 10:27PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Onyman T Onyman T 05/06/20 10:31PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Onyman T Onyman T 05/06/20 11:14PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Joel P Joel P 05/07/20 12:55AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Onyman T Onyman T 05/07/20 02:44PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Dirty30 Dillon Dirty30 Dillon 05/07/20 03:34PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Blake Totally a real doctor Blake Totally a real doctor 05/07/20 03:54PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Onyman T Onyman T 05/07/20 04:03PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Blake Totally a real doctor Blake Totally a real doctor 05/07/20 04:12PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Onyman T Onyman T 05/07/20 08:41PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Gerry F Gerry F 05/07/20 10:03PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Blake Totally a real doctor Blake Totally a real doctor 05/07/20 10:40PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Onyman T Onyman T 05/06/20 11:43PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Gerry F Gerry F 05/07/20 10:11PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Mike A Mike A 05/08/20 05:53PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Gerry F Gerry F 06/22/20 01:53PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Phil M Phil M 05/10/20 07:37AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Phil M Phil M 05/10/20 08:54AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Phil M Phil M 05/10/20 07:38AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 05/10/20 02:50PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Onyman T Onyman T 05/11/20 04:54PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Onyman T Onyman T 05/12/20 11:05AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 05/15/20 09:11PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 05/19/20 04:00PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Joel P Joel P 05/15/20 11:08PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 05/19/20 04:01PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Born to be WillD Born to be WillD 06/23/20 02:18AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Mike A Mike A 06/23/20 08:08PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Dirty30 Dillon Dirty30 Dillon 06/23/20 08:09PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: P D P D 06/23/20 08:36PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Mike A Mike A 06/23/20 11:49PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Gerry F Gerry F 10/04/20 12:29AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Dirty30 Dillon Dirty30 Dillon 06/23/20 09:29PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 06/28/20 06:44PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 07/05/20 05:12PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 07/10/20 10:22PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Brian Arnone Brian Arnone 07/07/20 09:00PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Phil M Phil M 07/07/20 11:35PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Brian Arnone Brian Arnone 07/08/20 01:19AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Roger Suarez Roger Suarez 07/08/20 08:50AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 07/10/20 10:29PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 07/10/20 10:34PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Roger Suarez Roger Suarez 07/10/20 11:18PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 07/11/20 10:30AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 07/25/20 02:10PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 07/25/20 06:27PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 07/25/20 06:30PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 07/25/20 06:35PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Andrew Wrase Andrew Wrase 03/12/21 07:40PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 08/11/21 11:50PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Dirty30 Dillon Dirty30 Dillon 08/12/21 12:19PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: bryan j. bryan j. 08/08/21 10:33AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 08/23/21 01:18PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/10/21 06:30PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/10/21 07:03PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 08/23/21 02:27PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/10/21 06:11PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Simon Williams Simon Williams 09/12/21 04:28AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Simon Williams Simon Williams 09/12/21 04:44AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Simon Williams Simon Williams 09/12/21 04:49AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/12/21 01:54PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/12/21 01:59PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/12/21 02:07PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/12/21 02:43PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Simon Williams Simon Williams 09/12/21 03:24PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/12/21 03:39PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Joel P Joel P 09/12/21 04:55PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/12/21 03:41PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 09/13/21 03:53PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/12/21 04:11PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/13/21 07:59PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/14/21 07:34PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Simon Williams Simon Williams 09/20/21 07:59AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/25/21 02:41PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Simon Williams Simon Williams 09/13/21 06:16AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 09/13/21 08:24PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/13/21 08:34PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Simon Williams Simon Williams 09/14/21 04:33PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Simon Williams Simon Williams 09/14/21 04:37PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/25/21 02:46PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/25/21 03:17PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 09/25/21 07:30PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ryan Graeme Ryan Graeme 09/26/21 06:23AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/26/21 09:15AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/27/21 09:04AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 09/27/21 08:42PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 12/12/21 05:00PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Ted Kenny Ted Kenny 12/12/21 05:09PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Simon Williams Simon Williams 09/27/21 05:57AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Simon Williams Simon Williams 09/27/21 11:28AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Simon Williams Simon Williams 09/28/21 02:59PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 10/02/21 01:08AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Simon Williams Simon Williams 10/03/21 12:45PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Satan 666 Satan 666 10/29/21 10:17PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 11/03/21 09:50AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Satan 666 Satan 666 11/03/21 10:01AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 11/10/21 07:40PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 11/18/21 03:35PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 11/23/21 10:58AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: P D P D 11/23/21 11:14AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Roger Suarez Roger Suarez 11/25/21 12:10PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 11/26/21 01:13PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Garrett The Kid Garrett The Kid 11/26/21 02:14PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 11/27/21 06:09PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Dirty30 Dillon Dirty30 Dillon 11/27/21 11:09PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Garelli Master✨ Garelli Master✨ 12/23/21 03:52AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 01/11/22 05:49PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Gerry F Gerry F 01/28/22 02:00PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Dirty30 Dillon Dirty30 Dillon 01/28/22 08:51PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Born to be WillD Born to be WillD 02/10/22 09:35AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 11/28/21 04:25PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 01/22/22 03:22PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: P D P D 01/22/22 04:30PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 01/28/22 04:23PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: P D P D 01/28/22 04:54PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Simon Williams Simon Williams 02/04/22 05:51PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 02/08/22 10:12PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Simon Williams Simon Williams 02/09/22 04:56PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 04/11/22 10:43AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Blake Totally a real doctor Blake Totally a real doctor 04/11/22 11:34AM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 04/11/22 01:10PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Nate K Nate K 05/11/22 01:50PM
  Re: Yamaha RD60 Megathread (Shifty50 content)Re: Garrett The Kid Garrett The Kid 05/11/22 02:41PM
