Re: Tjt treatland steel hobbit rumpus plate
jordan * /
Truth, I didn't think about rear shaft vs crankshaft rpm reductions. I 'should' get a start v but that's another expensive rabbit hole to go down.
You do a good sell on the Hobbit clutches...
but the many puch clutches I've bent posts on kinda make me want a brace if I'm doing some stupid shit. I've been looking at that Malossi Delta clutch. Some scooter forum said the shoes on that are 110g each, i bet if I could get that down to the 70-80g range that'd play nicer. I needa weigh the derbi shoes and see what those are at and if that would get me in the ballpark. Other than that, spring rate is spring rate. The same thickness and coil count would need the same amount of force to move it, right? The same mass of shoe would exert a similar amount of force against that spring rate.
If the derbi shoes are wayyy lighter then yea it sounds like hobbit clutch is what's up
But I did measure a vino clutch the other day, that was 102mm and fit in derbi bell fine
  Tjt treatland steel hobbit rumpus plateTopic by: Totally normal JBOT Totally normal JBOT 07/09/18 03:57PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/09/18 04:18PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/09/18 04:28PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/09/18 04:30PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Mike Boyd Mike Boyd 07/09/18 06:26PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/09/18 06:42PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Travis Noll Travis Noll 07/09/18 10:09PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/09/18 10:12PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/10/18 07:13PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Steve Paul Steve Paul 07/11/18 09:15AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/11/18 12:03PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/11/18 12:33PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/11/18 01:03PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/11/18 01:11PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/11/18 01:24PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Steve Paul Steve Paul 07/11/18 08:02PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Ryan . Ryan . 07/11/18 08:37PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/11/18 08:44PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/11/18 09:39PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Steve Paul Steve Paul 07/12/18 09:28AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 10:31AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 07/12/18 09:56AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Emil Kniemel Emil Kniemel 07/12/18 12:29PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/12/18 12:36PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 01:18PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 07/12/18 01:21PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/12/18 01:36PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 01:46PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/12/18 02:00PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Emil Kniemel Emil Kniemel 07/12/18 02:55PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/12/18 03:01PM
  Re: Tjt treatland steel hobbit rumpus plateRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/12/18 01:46PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 03:29PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/12/18 03:37PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/12/18 03:42PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 03:55PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/12/18 05:01PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/12/18 05:03PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 05:24PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Chris . Chris . 07/12/18 08:01PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/12/18 11:05PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 11:31PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/12/18 11:53PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/13/18 01:16AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/13/18 03:05AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/13/18 04:56PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/13/18 05:07PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/13/18 06:23PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Steve Paul Steve Paul 07/14/18 12:11AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/14/18 12:20AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/15/18 09:17PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/15/18 09:56PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/15/18 10:59PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/15/18 11:12PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Anthony B Anthony B 06/19/19 03:48PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 06/25/19 10:55AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 06/25/19 11:21AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 06/25/19 11:55AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 06/25/19 12:55PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 06/25/19 01:07PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 06/21/19 10:30PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 06/21/19 11:16PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 06/22/19 01:36PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 06/22/19 04:12PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 06/25/19 12:17PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 06/26/19 06:33PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 06/27/19 09:37AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Abdiel Gonzalez Abdiel Gonzalez 07/27/19 08:33PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 07/28/19 03:14AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Abdiel Gonzalez Abdiel Gonzalez 08/01/19 04:09PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 08/01/19 10:15PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 08/01/19 10:22PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Emil Kniemel Emil Kniemel 03/11/20 06:03PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 03/11/20 07:20PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Daniel '' Daniel '' 03/11/20 11:59PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 03/12/20 11:06AM
  Re: Tjt treatland steel hobbit rumpus plateRe: MPB Andyrew MPB Andyrew 03/12/20 11:45AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Abdiel Gonzalez Abdiel Gonzalez 08/01/19 10:51PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 08/14/19 02:39PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Chris Szuba Chris Szuba 08/20/19 10:39AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Happy Pancake Happy Pancake 08/28/19 07:09PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Mike Boyd Mike Boyd 08/29/19 12:10PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Happy Pancake Happy Pancake 08/29/19 09:30PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Happy Pancake Happy Pancake 09/01/19 06:02PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 03/11/20 08:15PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 03/12/20 12:30AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Emil Kniemel Emil Kniemel 03/12/20 02:33AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Pritza R&D Pritza R&D 03/12/20 12:19PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Daniel '' Daniel '' 03/12/20 01:43PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 03/12/20 02:52PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 03/12/20 07:21PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 03/12/20 08:57PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 03/12/20 11:32PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Totally normal JBOT Totally normal JBOT 03/13/20 01:02AM
