Re: Tjt treatland steel hobbit rumpus plate
Crazy Wayne /
I cut down the pin retaining sleeve.
Use my Dremel and elongated the angled torque driver slot.
And the BX belts it's nice and hi this is a new belt by the way in the picture so yeah I could probably get away with running a half inch belt
The belt in the rear shiv will travel up and down 19 mm.
That tjt was giving me about 7/8 on the front but it is a smaller radius but it works out for the both even with just a little bit of extra travel range on the rear contra sembly as long as I have the belt properly adjusted.
I suspect a lot of people who just slot the front variator on stock bike and don't modify the rear or basically getting into a real high-tension point and this is probably one of the aggravating factors I'm breaking the stock crankshaft but they will still break either way so if they need to be replaced as most of us already know.
  Tjt treatland steel hobbit rumpus plateTopic by: JBOT Admin JBOT Admin 07/09/18 03:57PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/09/18 04:18PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/09/18 04:28PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/09/18 04:30PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Mike Boyd Mike Boyd 07/09/18 06:26PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/09/18 06:42PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Travis Noll Travis Noll 07/09/18 10:09PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/09/18 10:12PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/10/18 07:13PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Ungapped rings to bind them all Ungapped rings to bind them all 07/11/18 09:15AM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/11/18 12:03PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/11/18 12:33PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/11/18 01:03PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/11/18 01:11PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/11/18 01:24PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Ungapped rings to bind them all Ungapped rings to bind them all 07/11/18 08:02PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Ryan . Ryan . 07/11/18 08:37PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/11/18 08:44PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/11/18 09:39PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Ungapped rings to bind them all Ungapped rings to bind them all 07/12/18 09:28AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 10:31AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 07/12/18 09:56AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Emil Kniemel Emil Kniemel 07/12/18 12:29PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 12:36PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 01:18PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 07/12/18 01:21PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 01:36PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 01:46PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 02:00PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Emil Kniemel Emil Kniemel 07/12/18 02:55PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 03:01PM
  Re: Tjt treatland steel hobbit rumpus plateRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/12/18 01:46PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 03:29PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 03:37PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 03:42PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 03:55PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 05:01PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 05:03PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 05:24PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Chris . Chris . 07/12/18 08:01PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 11:05PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 11:31PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 11:53PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/13/18 01:16AM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/13/18 03:05AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/13/18 04:56PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/13/18 05:07PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/13/18 06:23PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Ungapped rings to bind them all Ungapped rings to bind them all 07/14/18 12:11AM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/14/18 12:20AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/15/18 09:17PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/15/18 09:56PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/15/18 10:59PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/15/18 11:12PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Anthony B Anthony B 06/19/19 03:48PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 06/25/19 10:55AM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 06/25/19 11:21AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 06/25/19 11:55AM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 06/25/19 12:55PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 06/25/19 01:07PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 06/21/19 10:30PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 06/21/19 11:16PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 06/22/19 01:36PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 06/22/19 04:12PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 06/25/19 12:17PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 06/26/19 06:33PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 06/27/19 09:37AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Abdiel Gonzalez Abdiel Gonzalez 07/27/19 08:33PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/28/19 03:14AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Abdiel Gonzalez Abdiel Gonzalez 08/01/19 04:09PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 08/01/19 10:15PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 08/01/19 10:22PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Emil Kniemel Emil Kniemel 03/11/20 06:03PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 03/11/20 07:20PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Daniel '' Daniel '' 03/11/20 11:59PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 03/12/20 11:06AM
  Re: Tjt treatland steel hobbit rumpus plateRe: MPB Andyrew MPB Andyrew 03/12/20 11:45AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Abdiel Gonzalez Abdiel Gonzalez 08/01/19 10:51PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 08/14/19 02:39PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Chris Szuba Chris Szuba 08/20/19 10:39AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Happy Pancake Happy Pancake 08/28/19 07:09PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Mike Boyd Mike Boyd 08/29/19 12:10PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Happy Pancake Happy Pancake 08/29/19 09:30PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Happy Pancake Happy Pancake 09/01/19 06:02PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 03/11/20 08:15PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 03/12/20 12:30AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Emil Kniemel Emil Kniemel 03/12/20 02:33AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Pritza R&D Pritza R&D 03/12/20 12:19PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Daniel '' Daniel '' 03/12/20 01:43PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 03/12/20 02:52PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 03/12/20 07:21PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 03/12/20 08:57PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 03/12/20 11:32PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 03/13/20 01:02AM
