Re: Tjt treatland steel hobbit rumpus plate
DrGeorgeTompson (Alan) /
> Emil Kniemel Wrote:
> on the topic of belts, i came across this on the moped reddit. but you
> know, its reddit so maybe their info is suspect:
> "$3.99 (+tax) bargain at AutoZone! For all you PA50ii owners out there,
> get this belt if you need a cheap replacement! (maybe the
> PA50/Hobbit/Camino as well, don’t have any to try.) So far it works like
> a charm AND has teeth!"
> https://i.redditmedia.com/fZPHo0ws8LNB260trV_ZlF68iBZKRNcik6BPrpYQ41c.jpg?fit=crop&crop=faces%2Centropy&arh=2&w=640&s=6943fde3bded5cb5be368999cae628bf
> but for $3.99 itll prolly get you home if your belt ever disintegrated
> on a ride.
These work pretty good on vespas too. I ran a 17425 with 108mm cheeks for a while; i think the motor was all the way forward.
They are actually 17/32" belts so they make a good bridge between the AX and BX profile belts.
They are the same width as the vespa malossi belts (13.4m) but are a little bit taller. They would wear out fast and make for hard starting after 150 miles or so. $4 tho so whatever.
I did get a top cog variant once and it seemed to last a little longer and everyone will tell you the belt is inside out.
  Tjt treatland steel hobbit rumpus plateTopic by: JBOT Admin JBOT Admin 07/09/18 03:57PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/09/18 04:18PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/09/18 04:28PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/09/18 04:30PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Mike Boyd Mike Boyd 07/09/18 06:26PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/09/18 06:42PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Travis Noll Travis Noll 07/09/18 10:09PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/09/18 10:12PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/10/18 07:13PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Ungapped rings to bind them all Ungapped rings to bind them all 07/11/18 09:15AM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/11/18 12:03PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/11/18 12:33PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/11/18 01:03PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/11/18 01:11PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/11/18 01:24PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Ungapped rings to bind them all Ungapped rings to bind them all 07/11/18 08:02PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Ryan . Ryan . 07/11/18 08:37PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/11/18 08:44PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/11/18 09:39PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Ungapped rings to bind them all Ungapped rings to bind them all 07/12/18 09:28AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 10:31AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 07/12/18 09:56AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Emil Kniemel Emil Kniemel 07/12/18 12:29PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 12:36PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 01:18PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 07/12/18 01:21PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 01:36PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 01:46PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 02:00PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Emil Kniemel Emil Kniemel 07/12/18 02:55PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 03:01PM
  Re: Tjt treatland steel hobbit rumpus plateRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/12/18 01:46PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 03:29PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 03:37PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 03:42PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 03:55PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 05:01PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 05:03PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 05:24PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Chris . Chris . 07/12/18 08:01PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 11:05PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 11:31PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 11:53PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/13/18 01:16AM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/13/18 03:05AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/13/18 04:56PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/13/18 05:07PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/13/18 06:23PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Ungapped rings to bind them all Ungapped rings to bind them all 07/14/18 12:11AM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/14/18 12:20AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/15/18 09:17PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/15/18 09:56PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/15/18 10:59PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/15/18 11:12PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Anthony B Anthony B 06/19/19 03:48PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 06/25/19 10:55AM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 06/25/19 11:21AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 06/25/19 11:55AM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 06/25/19 12:55PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 06/25/19 01:07PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 06/21/19 10:30PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 06/21/19 11:16PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 06/22/19 01:36PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 06/22/19 04:12PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 06/25/19 12:17PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 06/26/19 06:33PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 06/27/19 09:37AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Abdiel Gonzalez Abdiel Gonzalez 07/27/19 08:33PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/28/19 03:14AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Abdiel Gonzalez Abdiel Gonzalez 08/01/19 04:09PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 08/01/19 10:15PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 08/01/19 10:22PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Emil Kniemel Emil Kniemel 03/11/20 06:03PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 03/11/20 07:20PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Daniel '' Daniel '' 03/11/20 11:59PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 03/12/20 11:06AM
  Re: Tjt treatland steel hobbit rumpus plateRe: MPB Andyrew MPB Andyrew 03/12/20 11:45AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Abdiel Gonzalez Abdiel Gonzalez 08/01/19 10:51PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 08/14/19 02:39PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Chris Szuba Chris Szuba 08/20/19 10:39AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Happy Pancake Happy Pancake 08/28/19 07:09PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Mike Boyd Mike Boyd 08/29/19 12:10PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Happy Pancake Happy Pancake 08/29/19 09:30PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Happy Pancake Happy Pancake 09/01/19 06:02PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 03/11/20 08:15PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 03/12/20 12:30AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Emil Kniemel Emil Kniemel 03/12/20 02:33AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Pritza R&D Pritza R&D 03/12/20 12:19PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Daniel '' Daniel '' 03/12/20 01:43PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 03/12/20 02:52PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 03/12/20 07:21PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 03/12/20 08:57PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 03/12/20 11:32PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 03/13/20 01:02AM
