Re: Tjt treatland steel hobbit rumpus plate
Ungapped rings to bind them all /
> JBOT Admin Wrote:
> Stamped or Cnc, if the curves are the same it doesn't matter how it's
> made.
> They will be stamped in the future for cost savings I bet and it should
> perform exactly the same
Gotta disagree on that one. The stamped version is a linear (45 degree angle?) ramp. CNC machining allows a variation.. heh heh.. of the resistance along the plate travel that will have a different effect on the "shift curve" IMO... It's almost a french curve.. kind of like the original plates.. starting with a large, flat radius and transitioning to a steeper response as the rollers travel out with greater force, which is probably why it works well with weaker springs?? No complaints on the CNC'd price at $40! I like the 18 x 14s for accel + full variation but they aren't readily available in a wide range of weights like the 16 x 13s. :((edited)
  Tjt treatland steel hobbit rumpus plateTopic by: JBOT Admin JBOT Admin 07/09/18 03:57PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/09/18 04:18PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/09/18 04:28PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/09/18 04:30PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Mike Boyd Mike Boyd 07/09/18 06:26PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/09/18 06:42PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Travis Noll Travis Noll 07/09/18 10:09PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/09/18 10:12PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/10/18 07:13PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Ungapped rings to bind them all Ungapped rings to bind them all 07/11/18 09:15AM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/11/18 12:03PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/11/18 12:33PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/11/18 01:03PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/11/18 01:11PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/11/18 01:24PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Ungapped rings to bind them all Ungapped rings to bind them all 07/11/18 08:02PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Ryan . Ryan . 07/11/18 08:37PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/11/18 08:44PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/11/18 09:39PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Ungapped rings to bind them all Ungapped rings to bind them all 07/12/18 09:28AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 10:31AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 07/12/18 09:56AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Emil Kniemel Emil Kniemel 07/12/18 12:29PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 12:36PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 01:18PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 07/12/18 01:21PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 01:36PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 01:46PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 02:00PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Emil Kniemel Emil Kniemel 07/12/18 02:55PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 03:01PM
  Re: Tjt treatland steel hobbit rumpus plateRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 07/12/18 01:46PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 03:29PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 03:37PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 03:42PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 03:55PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 05:01PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 05:03PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 05:24PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Chris . Chris . 07/12/18 08:01PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 11:05PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/12/18 11:31PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/12/18 11:53PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/13/18 01:16AM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/13/18 03:05AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/13/18 04:56PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/13/18 05:07PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/13/18 06:23PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Ungapped rings to bind them all Ungapped rings to bind them all 07/14/18 12:11AM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/14/18 12:20AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/15/18 09:17PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/15/18 09:56PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/15/18 10:59PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Crazy Wayne Crazy Wayne 07/15/18 11:12PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Anthony B Anthony B 06/19/19 03:48PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 06/25/19 10:55AM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 06/25/19 11:21AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 06/25/19 11:55AM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 06/25/19 12:55PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 06/25/19 01:07PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 06/21/19 10:30PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 06/21/19 11:16PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 06/22/19 01:36PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 06/22/19 04:12PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 06/25/19 12:17PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 06/26/19 06:33PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Dirty30 Dillon Dirty30 Dillon 06/27/19 09:37AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Abdiel Gonzalez Abdiel Gonzalez 07/27/19 08:33PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 07/28/19 03:14AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Abdiel Gonzalez Abdiel Gonzalez 08/01/19 04:09PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 08/01/19 10:15PM
  Re: Tjt treatland steel hobbit rumpus plateRe: JBOT Admin JBOT Admin 08/01/19 10:22PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Abdiel Gonzalez Abdiel Gonzalez 08/01/19 10:51PM
  Re: Tjt treatland steel hobbit rumpus plateRe: jordan * jordan * 08/14/19 02:39PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Chris Szuba Chris Szuba 08/20/19 10:39AM
  Re: Tjt treatland steel hobbit rumpus plateRe: Happy Pancake Happy Pancake 08/28/19 07:09PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Mike Boyd Mike Boyd 08/29/19 12:10PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Happy Pancake Happy Pancake 08/29/19 09:30PM
  Re: Tjt treatland steel hobbit rumpus plateRe: Happy Pancake Happy Pancake 09/01/19 06:02PM
